Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Sheet name to equal active model file name & revision number
2 REPLIES 2
GKPByDesign
324 Views, 2 Replies
Hey I had this code solved on here before which grabs the active model's file name to name the sheet the same name, I now want to add the revision to the file name: eg File name & "-" & Rev number. I know illogic well, but logic in drawings is hard!
Sub Main()
'Purpose: Push file name to sheet name
'21-Sept-16
Dim oDoc As Document = ThisApplication.ActiveDocument
Dim oSheet As Sheet
Dim oDrawingView As DrawingView
'Iterate through sheets
For Each oSheet In oDoc.Sheets
    'Grab the first drawing view on the sheet
    oDrawingView = oSheet.DrawingViews(1)
    'Grab the model of the first drawing view
    oModel = oDrawingView.ReferencedDocumentDescriptor.ReferencedDocument
     'Assign the sheet name based off of the file name, with the path and extension removed
    oSheet.Name = System.IO.Path.GetFileNameWithoutExtension(oModel.FullFileName) & "-" & o_iProp
Next
End Sub
2 REPLIES 2
@GKPByDesign,
Try below iLogic code to rename the sheet.
Sub Main()
'21-Sept-16
Dim oSheet As Sheet
    Dim oModel As Document
	Msgbox("1")
	Dim oRev As String
	oRev = oModel.PropertySets.Item("Inventor Summary Information").Item("Revision Number").Value
    oSheet.Name = System.IO.Path.GetFileNameWithoutExtension(oModel.FullFileName) & "-" & oRev
Next
End Sub
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Hey the code almost worked, but you had a rouge bit of code to show a message box?
Sub Main()
'21-Sept-16
Dim oSheet As Sheet
	Dim oRev As String
Next
End Sub
Technology Administrators
