Sheet Metal - Ilogic
12 REPLIES 12
Message 1 of 13
iva.btblan
793 Views, 12 Replies
I can't figure out the error in the rule.
Someone can help to understand.
I can not find the error.
Thank you!
12 REPLIES 12
Message 2 of 13
JelteDeJong
in reply to: iva.btblan
I cant open your model (other version) but what i understand from the pdf is that you want to update the parameters in the model 09.04.00100:1 from a rule in the assembly. In that case you need to turn around the statements in your code.:
Parmeter("09.04.00100:1", "Thickness") = Espessura
Parmeter("09.04.00100:1", "Comprimento") = Comprimento
Jelte de Jong
Blog: hjalte.nl - github.com
Message 3 of 13
iva.btblan
in reply to: JelteDeJong
I made the changes.
The problems with the thickness I can not solve.
I'm sending the pictures to understand better.
Can you help me?
Message 4 of 13
JelteDeJong
sry thickness parameter cant be edit directy. but with the following code it should work:
Dim doc As AssemblyDocument = ThisApplication.ActiveDocument
Dim occ As ComponentOccurrence = doc.ComponentDefinition.Occurrences.ItemByName("09.04.00100:1")
Dim partDoc As PartDocument = occ.ReferencedDocumentDescriptor.ReferencedDocument
Dim sheetmetalDef As SheetMetalComponentDefinition = partDoc.ComponentDefinition
sheetmetalDef.ActiveSheetMetalStyle.Thickness = Thickness
Jelte de Jong
Message 5 of 13
iva.btblan
Thank you for your attention!
I performed according to orientation.
Going a problem and I can't solve it.
You can help me. Again?
Message 6 of 13
JelteDeJong
try this: (i changed the variable thickness to Espessura)
sheetmetalDef.ActiveSheetMetalStyle.Thickness = Espessura
Jelte de Jong
Message 7 of 13
iva.btblan
Excellent. Worked.
Thank you!
Without your help, you'd never make it.
Why is this message sruge?
Message 8 of 13
iva.btblan
What is the best way to control 09.04.00012?
Thanks for helping.
Message 9 of 13
iva.btblan
How to eliminate this error?
Message 10 of 13
@iva.btblan,
Please provide non confidential data and steps to reproduce the scenario.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Message 11 of 13
Can I send the files?
Message 12 of 13
@iva.btblan,
Yes, you can send files. Make sure that files are non confidential.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 13 of 13
I managed to solve the problem!
Thank you for your attention.
I am doubtful about another matter.
I will be shipping soon.
How do I warn you?
