Sheet metal DXF (sorting and adding text)
13 REPLIES 13
Message 1 of 14
2842 Views, 13 Replies
I "borrowed" some code I found on the Forum to make DXF files.
In an individual setting these codes work after some adjustments. But I can't get them to run combined as my knowledge with iLogic still has to improve.
What I want:
I want a to run the rule in the main assembly.
  • There it looks which parts are sheet metal
  • if sheet metal:
    • Sort  files in folders according to Material and Thickness (works)
    • Create the DXF with some specific colors (works)
    • Add some text in the middle of the DXF with: Part number, Quantity (is specified in our parts with Keywords), Material and Thickness. (doesn't work)
I believe it screws up with some referencing but I'm not sure
Any help would be highly appreciated!
This is the code which I combined (add it to an assembly with some sheet metal parts):
'https://forums.autodesk.com/t5/Inventor-customization/export-To-dxf-In-separate-folders-By-thickness/m-p/8891417
Sub Main()
    Dim New_Folder_Path As String = ThisDoc.Path
    Dim oAsmDoc As AssemblyDocument = ThisDoc.Document
    My.Computer.FileSystem.CreateDirectory(New_Folder_Path)
    'Ask user for REV level
    Dim Rev_Level As String = ""
    Rev_Level = InputBox ("Enter Rev Level","Creating DXF files For Entire Assembly")
    Dim Count_up As Integer = 0
    Dim Gauge_Folders(12) As String
    Dim Ga As String
    Dim doc As Document
	Dim R_Part As String
	Dim oMaterial As Material
	'TOEVOEGING!
	oPath = ThisDoc.Path
	FileNameNoExt = ThisDoc.FileName(False) 'without extension
	Dim Props As String = AddDXFProperties( True)
	Dim aryProps() As String = Split(Props,"\P")
	Dim PropVal(3) As String
	For i = 0 To UBound(aryProps)
		Dim PropSplitVal() As String = Split(aryProps(i),":")
		PropVal(i) = Trim(PropSplitVal(1))
		PropResults = PropResults & vbNewLine & aryProps(i)
	Next
	'EINDE TOEVOEGING
    For Each doc In oAsmDoc.AllReferencedDocuments
        If doc.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
			Try
				R_Part = doc.DisplayName
				oMaterial = doc.ComponentDefinition.Material
				Gauge_Path = New_Folder_Path & "\DXF\" & oMaterial.Name & " - " & Parameter(R_Part, "Thickness") &"mm"
							MessageBox.Show(Gauge_Path )
				Try
					My.Computer.FileSystem.CreateDirectory(Gauge_Path)
				Catch
				End Try
            	Call Make_DXF(doc, Rev_Level, Gauge_Path)
				'TOEVOEGING!
				'MsgBox("Oproepen AddDXFPropperties")
				Call AddDXFProperties()
				'MsgBox("Oproepen AddDXFPropperties gelukt")
			Catch
			End Try
		End If
    Next
MsgBox("DXF Export Complete",,"All Done")
End Sub
Sub Make_DXF(oDoc As Document, Rev_L As String, File_Location As String)
	ThisApplication.Documents.Open(oDoc.FullFileName, True)
	Dim Part_Name As String = oDoc.DisplayName
	Dim TestPos As Integer = 0
	Dim Rev_Adder As String = ""
	If Rev_L <> "" Then Rev_Adder = " REV " & Rev_L
	TestPos = InStr(1, Part_Name, ".")
	If TestPos <> 0 Then Part_Name = Left(Part_Name, InStr(Part_Name, ".")-1)
	Dim New_Name As String = Part_Name
	Dim oFilename As String  = File_Location & "\" & New_Name & Rev_Adder & ".dxf"
	Dim oCompDef As SheetMetalComponentDefinition = oDoc.ComponentDefinition
	If oCompDef.HasFlatPattern = False Then
		oCompDef.Unfold
	Else
		oCompDef.FlatPattern.Edit
	End If
	'TOEVOEGING
	Dim sOut As String
	sOut = "FLAT PATTERN DXF?AcadVersion=2018" _
			+ "&InteriorProfileLayer=IV_INTERIOR_PROFILES" _
			+ "&InteriorProfilesLayerColor=255;255;0" _
			+ "&OuterProfileLayer=IV_EXTERIOR_PROFILES" _
			+ "&InvisibleLayers=IV_TANGENT" _
			+ "&SimplifySplines=True" _
			+ "&BendLayerLineType=37634" _
			+ "&BendLayerColor=255;255;0" _
			+ "&BendUpLayerLineType=37634" _
			+ "&BendUpLayerColor=255;0;0" _
			+ "&BendDownLayerLineType=37634" _
			+ "&BendDownLayerColor=0;255;0" _
			+ "&FeatureProfilesLayerLineType=37634" _
			+ "&FeatureProfilesLayerColor=255;255;0" _
			+ "&FeatureProfilesUpLayerLineType=37634" _
			+ "&FeatureProfilesUpLayerColor=255;255;0" _
			+ "&FeatureProfilesDownLayerLineType=37634" _
			+ "&FeatureProfilesDownLayerColor=255;255;0"
	'EINDE TOEVOEGING
	Dim oFlatPattern As FlatPattern = oCompDef.FlatPattern
	Dim oFace As Face = oFlatPattern.TopFace
	Dim oCommand As CommandManager = ThisApplication.CommandManager
	oCommand.DoSelect(oFace)
	oCommand.PostPrivateEvent(PrivateEventTypeEnum.kFileNameEvent, oFilename)
	oCompDef.DataIO.WriteDataToFile (sOut, oFilename)
	'========Oude Commando (Vervangen door regel hier boven ============
	'oCommand.ControlDefinitions.Item("GeomToDXFCommand").Execute2(True)
	oCompDef.FlatPattern.ExitEdit
	oDoc.Close
End Sub
'Haalt de gegevens op zoals PartNummer, Materiaal en Aantal
'Bepaald ook de plaatsing van deze gegevens in de DXF
Public Function AddDXFProperties(Optional JustReturnText As Boolean = False) As String
'Generate the dxf properties to place in the dxf file as text.
'MsgBox("Begin")
Dim PartNummer As String = "Part Nummer: " & UCase(ThisDoc.FileName(False)) 'false = without extension '(iProperties.Value("Project", "Part Number")) 'without extension
Dim Aantal As String = "Aantal: " & UCase(iProperties.Value("Summary", "Keywords"))
Dim Materiaal As String = "Materiaal: " & UCase(iProperties.Material)
Dim Dikte As String = "Dikte: " & UCase(Thickness)
Dim sText As String = PartNummer & "\P" & Aantal & "\P" & Materiaal & "\P" & Dikte
'Plaatsing tekst
'MsgBox("PlaatsenTEXT")
If JustReturnText = False Then
	extents_length = SheetMetal.FlatExtentsLength
	extents_width = SheetMetal.FlatExtentsWidth
	PosX = extents_length/2
	PosY = extents_width/-2
	'Part Nummer
	'MsgBox("Call EditDXFFile")
	Call EditDXFFile(PartNummer, PosX, PosY, FileName, "1D5")
	'MsgBox("Call EditDXFFile gelukt?")
	'Aantal
	Call EditDXFFile(Aantal, PosX, PosY - 5, FileName, "1D6")
	'Materiaal
	Call EditDXFFile(Materiaal, PosX, PosY - 10, FileName, "1D7")
	'Dikte
	Call EditDXFFile(Dikte, PosX, PosY - 15, FileName, "1D8")
End If
AddDXFProperties = sText
End Function
'Voegt de tekst toe aan de DXF? Tekstgrote is hier te wijzigen
'Wordt opgeroepen door Public Function AddDXFProperties
Public Sub EditDXFFile(TextToAdd As String, PosX As Double, PosY As Double, FileName As String, IDnumber As String)
	'FileName has No pathway and No Extension
	'Add required text to edit the dxf file (3,55 is de tekstgrote om te wijzigen op het moment)
	Dim RequiredText As String =  "TEXT" _
		& vbNewLine & "  5" _
		& vbNewLine & IDnumber _
		& vbNewLine & "330" _
		& vbNewLine & "71" _
		& vbNewLine & "100" _
		& vbNewLine & "AcDbEntity" _
		& vbNewLine & "  8" _
		& vbNewLine & "0" _
		& vbNewLine & "AcDbText" _
		& vbNewLine & " 10" _
		& vbNewLine & PosX _
		& vbNewLine & " 20" _
		& vbNewLine & PosY _
		& vbNewLine & " 30" _
		& vbNewLine & "0.0" _
		& vbNewLine & " 40" _
		& vbNewLine & "3.55" _ 'Text Height
		& vbNewLine & "  1" _
		& vbNewLine
	Dim realTextToAdd As String = RequiredText & TextToAdd _
		& vbNewLine & "0" _
		& vbNewLine
	Dim textLen As Integer = realTextToAdd.Length()
	FileName = ThisDoc.FileName(False)
	sFname = oPath & "\" & FileName & ".dxf"
'MsgBox("5")
	Dim readText As String = System.IO.File.ReadAllText(oFilename)
'MsgBox("5.1")
	Dim re As New System.Text.RegularExpressions.Regex("(?<=ENTITIES((?!ENDSEC).)*)ENDSEC", System.Text.RegularExpressions.RegexOptions.Singleline)
'MsgBox("5.2")
	Dim i As Integer = 0
'MsgBox("6")
	For Each match In re.Matches(readText)
		readText = readText.Insert(match.Index + textLen * i, realTextToAdd)
		i = i + 1
	Next
'MsgBox("7")
	System.IO.File.WriteAllText(oFilename, readText)
'MsgBox("8")
End Sub
And this is the code where I have the added text to work but only in a stand alone part:
'https://forums.autodesk.com/t5/inventor-customization/dxf-positioning/m-p/7599038
Sub Main
'Trigger = iTrigger0
'Exit Sub
'Get the pathway to the active document
Next
'Vraagt of je de gegevens wil aanpassen (Dit wil ik niet dus daarom uit)
'Answer = MessageBox.Show(PropResults & vbNewLine & vbNewLine & "Would you like edit any of these flat patterns properties?", "Flat Pattern Properties",MessageBoxButtons.YesNo,MessageBoxIcon.Question)
'If Answer = vbYes Then
'	iProperties.Value("Project", "Part Number") = InputBox("Enter the Part Number.", "Part Number", PropVal(0))
'	If Trim(iProperties.Value("Project", "Part Number")) = "" Then Exit Sub
'	iProperties.Value("Summary", "Keywords") = InputBox("Enter the quantity.", "Quantity", PropVal(1))
'	If Trim(iProperties.Value("Summary", "Keywords")) = ""  Then Exit Sub
'	iProperties.Material = InputBox("Enter the Material.", "Material", PropVal(2))
'	If Trim(iProperties.Material) = "" Then Exit Sub
'	'SheetMetal.SetActiveStyle(Matl)
'	iProperties.Value("Project", "Stock Number") = InputBox("Enter the Designer.", "Stock Number", PropVal(3))
'End If
Answer = MessageBox.Show("Would you like to create flat patterns for all parts in the active folder?", "Create Flat Patterns",MessageBoxButtons.YesNo,MessageBoxIcon.Question)
'set condition based on answer
	'See if user wants the files saved upon closing
	SaveDoc = CBool(MessageBox.Show("Do you wish to have the files saved upon closing?", "Save Files?",MessageBoxButtons.YesNo,MessageBoxIcon.Question))
	'Create the DXF for the active document first
	'Call CreateDXF(oPath)
	invApp = GetObject(, "Inventor.Application")
	'Get all File names in the active document's directory
	Dim FileEntries As String() = System.IO.Directory.GetFiles(oPath)
	'Loop through all the files in the active document's directory
	For i = 0 To UBound(FileEntries)
		'MsgBox(FileEntries(i))
		'Make sure the file is a part file.
		Extension = System.IO.Path.GetExtension(FileEntries(i))
		FileName = System.IO.Path.GetFileNameWithoutExtension(FileEntries(i))
		'MsgBox(Extension)
		If Extension = ".ipt" Then
			'Open the current file in the loop
			DwgToOpen = invApp.Documents
			'MsgBox ("Hello " & FileEntries(i))
			DwgToOpen.Open(FileEntries(i))
			ThisApplication.SilentOperation = True
			'See if the part is an iPart
			Dim oiPartDoc As PartDocument
    		oiPartDoc = invApp.ActiveDocument
			If oiPartDoc.ComponentDefinition.IsiPartFactory  Then
				'Create a flat pattern for each iPart Member
				Call LoopThruiParts(oPath)
			Else
				'Create Flat Pattern for the active document
				Call CreateDXF(oPath, FileName)
				'Do not close the initial file
				If FileNameNoExt <> FileName Then
					Dim DocToClose As Inventor.Document
					DocToClose = invApp.ActiveDocument
					'MsgBox(SaveDoc)
					DocToClose.Close(Not SaveDoc)
				End If
			End If
		End If
	Next
ElseIf Answer = vbNo Then
	Dim iPartDoc As PartDocument
	iPartDoc = ThisDoc.Document
	If iPartDoc.ComponentDefinition.IsiPartFactory  Then
	Else
		Call CreateDXF(oPath, ThisDoc.FileName(False))
	End If
End If
ThisApplication.SilentOperation = False
'iLogicVb.UpdateWhenDone = True
End Sub
Dim SaveDoc As Boolean
Dim ShowMsg As Boolean = True
Dim OverwriteFile As Boolean
'Maakt de DXF.
'Vraagt: Overschrijven, Maakt van Part een SheetMetal part, Unfold, Fold en set de DXF properties
Public Sub CreateDXF(oPath As String, sFname As String)
'MsgBox ("Hello CreateDXF")
'The file format will depend on the extension'Set file name extension to ".DXF"
'Create the full path and file name
sFname = oPath & "\" & sFname & ".dxf"
'MsgBox ("Hello Pathway")
'Check to see if the file exists
If System.IO.File.Exists(sFname) Then
	If ShowMsg = True Then
		OverwriteFile = CBool(MessageBox.Show("File " & sFname & " already exists." & vbNewLine & "Would you like to overwrite it ?" & vbNewLine & "This will not be asked again this session." , "Overwrite File",MessageBoxButtons.YesNo,MessageBoxIcon.Question))
	End If
	If OverwriteFile = False Then Exit Sub
End If
'Kijkt of het part geschikt is om een sheetmetal bestand van te maken.
'Kan volgens mij uit samen met de stukje 2 kopjes hier onder.
'MsgBox("About to test for file type")
Dim objDoc As Document = ThisApplication.ActiveEditDocument
'Make sure the open document is suitable for sheet metal (Must be a part file)
If objDoc.DocumentType <> kPartDocumentObject Then
	MessageBox.Show("A sheet metal part file must be active to generate the flat pattern.", "Invalid Part File!")
	Exit Sub
End If
'MsgBox("File type confirmed")
'get DXF target folder path
oFolder = oPath
Dim oDoc As PartDocument
'MsgBox("About to Set to Sheet Metal")
oDoc = ThisApplication.ActiveDocument
'Try setting the part file to sheet metal
'Kan volgens mij van standaard parts een sheetmetal part maken, de vraag is of dit gewenst is! Zo, niet uitschakelen!
Try
	oCompDef = oDoc.ComponentDefinition
Catch
	Exit Sub
End Try
'MsgBox("Sheet Metal Confirmed")
'Unfold the part file if it is not already unfolded
'	MsgBox("ABout to unfold")
	oCompDef.Unfold
'	MsgBox("Unfolded")
Else
'	MsgBox("About to edit flat pattern")
'	MsgBox("Flat pattern confirmed")
End If
'Set properties of the output file. Version of AutoCAD, Bendlines to Cyan, Remove the tangent lines
'Check for the DXF folder and create it if it does not exist
If Not System.IO.Directory.Exists(oFolder) Then
	System.IO.Directory.CreateDirectory(oFolder)
End If
'put the flat pattern to a file
'MsgBox("About to create dxf")
oCompDef.DataIO.WriteDataToFile (sOut, sFname)
'MsgBox("dxf created")
'Try switching back to the folded part
Try
Catch
    'MsgBox("Error Exitting Flat Pattern!")
End Try
'MsgBox("switched to folded part")
End Sub
'Volgende 4 regels uitgeschakeld, de waardes worden verderop bepaald.
'Dim RevisionNo As String = ThisApplication.ActiveDocument.PropertySets.Item("Inventor Summary Information").Item("Revision Number").Value
'Dim Designer As String = ThisApplication.ActiveDocument.PropertySets.Item("Design Tracking Properties").Item("Designer").Value
'Dim sMaterial As String = SheetMetal.GetActiveStyle()
'Dim FileName As String = ThisDoc.FileName(False) 'without extension
Dim PartNummer As String = "Part Nummer: " & UCase (ThisDoc.FileName(False)) 'false = without extension '(iProperties.Value("Project", "Part Number")) 'without extension
'Plaatsing tekst
	'Part Nummer
	'Aantal
	'Materiaal
	'Dikte
End If
End Function
	Dim RequiredText As String = "TEXT" & vbNewLine & "  5" & vbNewLine & IDnumber & vbNewLine & "330" & vbNewLine & "71"  & vbNewLine & "100"  & vbNewLine & "AcDbEntity" & vbNewLine & "  8" & vbNewLine  & "0" & vbNewLine & "100" & vbNewLine & "AcDbText"  & vbNewLine & " 10" & vbNewLine & PosX  & vbNewLine & " 20"  & vbNewLine & PosY  & vbNewLine & " 30" & vbNewLine & "0.0" & vbNewLine &" 40" & vbNewLine & "3.55" & vbNewLine & "  1" & vbNewLine
	Dim realTextToAdd As String = RequiredText & TextToAdd & vbNewLine & "100" & vbNewLine & "AcDbText" & vbNewLine & "0" & vbNewLine
	Dim readText As String = System.IO.File.ReadAllText(sFname)
		i = i + 1
	Next
	System.IO.File.WriteAllText(sFname, readText)
End Sub
'Plaatsing tekst en waardes ophalen iParts (zou in principe uitgeschakeld kunnen worden)
Public Sub LoopThruiParts(oPath As String)
	'This sub iterates thru all of the Part of an iPart Factory
	'An iPart must be the active document
	'Set Connection to active document
	oiPartDoc = ThisDoc.Document
	'Check to see it it's an iPart
		'Set a reference to the iPart Factory
		Dim oiPartFactory As iPartFactory
		oiPartFactory = oiPartDoc.ComponentDefinition.iPartFactory
		'Loop through all the rows in the iPart table and set that row to the active iPart
		For i = 1 To oiPartFactory.TableRows.Count
			Dim IPF As iPartFactory
			IPF = oiPartDoc.ComponentDefinition.iPartFactory
			Dim oRow As iPartTableRow
			oRow = IPF.TableRows.Item(i)
			IPF.DefaultRow = oRow
			FileName = iProperties.Value("Project", "Part Number")
'			Dim RevNo As String
'			If Val(iProperties.Value("Project", "Revision Number")) <= 0 Then
'				RevNo = "RV:1"
'			Else
'				RevNo = "RV:" & iProperties.Value("Project", "Revision Number")
'			End If
			Dim Materiaal As String = "Materiaal:" & iProperties.Material
			Dim Dikte As String = "Dikte: " & iProperties.Value("Summary", "Keywords")
			Dim Aantal As String = "Aantal: " & iProperties.Value("Summary", "Keywords")
			'Dim Routing As String = "ROUTING: " & RoutingNo
			'Call EditDXFFile(sText, PosX, PosY, FileName, IDnumber)
			'Part Nummer
			'Aantal
			'Materiaal
			'Dikte
		Next
	End If
End Sub
13 REPLIES 13
Message 2 of 14
I've done some more searching and I think I have a clue where it goes wrong.
In the "Public Sub EditDXFFile" part of the code it needs to get the value "oFilename" from the "Sub Make_DXF" but it doesn't get that value apparently.
I have done a lot of searching on the forum on how to get that value but I still have no idea how I should get it to work.
So a small question to get me going again: How do you send a value from on Sub to another?
Message 3 of 14
JhoelForshav
Hi @Anonymous
I've made some changes to your code. This works for me when I try it 🙂
Sub Main()
Rev_Level = InputBox("Enter Rev Level", "Creating DXF files For Entire Assembly")
Dim doc As Document
Dim Gauge_Path As String
		Try
			Gauge_Path = New_Folder_Path & "\DXF\" & oMaterial.Name & " - " & Parameter(R_Part, "Thickness") & "mm"
			'MessageBox.Show(Gauge_Path )
			Try
			Catch
			End Try
		Catch
		End Try
	End If
Next
MsgBox("DXF Export Complete", , "All Done")
End Sub
	'ThisApplication.Documents.Open(oDoc.FullFileName)
	If TestPos <> 0 Then Part_Name = Left(Part_Name, InStr(Part_Name, ".") -1)
		oCompDef.Unfold
	Else
	End If
	Dim sOut As String
	oFlatPattern.DataIO.WriteDataToFile(sOut, oFilename)
	AddDXFProperties(oDoc, oFilename, False)
	oDoc.Close
End Sub
Public Function AddDXFProperties(oDoc As PartDocument, oDxfFile As String, Optional JustReturnText As Boolean = False) As String
	Dim PartNummer As String = "Part Nummer: " & UCase(oDoc.PropertySets("Design Tracking Properties")("Part Number").Value)
	Dim Aantal As String = "Aantal: " & UCase(oDoc.PropertySets("Inventor Summary Information")("Keywords").Value)
	Dim Materiaal As String = "Materiaal: " & UCase(oDoc.PropertySets("Design Tracking Properties")("Material").Value)
	Dim Dikte As String = "Dikte: " & UCase(oDoc.ComponentDefinition.Thickness.Expression)
		Dim UoM As UnitsOfMeasure = oDoc.UnitsOfMeasure
		extents_length = UoM.ConvertUnits(oDoc.ComponentDefinition.FlatPattern.Length, UnitsTypeEnum.kDatabaseLengthUnits, UoM.LengthUnits)
		extents_width = UoM.ConvertUnits(oDoc.ComponentDefinition.FlatPattern.Width, UnitsTypeEnum.kDatabaseLengthUnits, UoM.LengthUnits)
		PosX = extents_length / 2
		PosY = extents_width / -2
		Call EditDXFFile(PartNummer, PosX, PosY, oDxfFile, "1D5")
		Call EditDXFFile(Aantal, PosX, PosY - 5, oDxfFile, "1D6")
		Call EditDXFFile(Materiaal, PosX, PosY - 10, oDxfFile, "1D7")
		Call EditDXFFile(Dikte, PosX, PosY - 15, oDxfFile, "1D8")
	End If
End Function
	& vbNewLine & "0" _
	& vbNewLine
	& vbNewLine & "0" _
	& vbNewLine
	Dim readText As String = System.IO.File.ReadAllText(FileName)
		i = i + 1
	Next
	System.IO.File.WriteAllText(FileName, readText)
End Sub
Message 4 of 14
in reply to: JhoelForshav
WOW thanks a lot @JhoelForshav !
I've tested it and everything seems to be working fine.
I only have to do some fine tuning with the positioning of the text within the DXF, sometimes it puts it just outside the part. But I think the has something to do with the face of the part.
I already put our codes next to each other to try and learn as much as possible but I need some more time to fully understand what is happening.
Again thank you very much!
Message 5 of 14
JhoelForshav
I'm glad it works @Anonymous 🙂
It wouldn't hurt to clean the code up a bit but I just focused on getting it to work.
Message 6 of 14
@JhoelForshav  Is there a way to set the text color or layer?
Message 7 of 14
3DAli
		i = i + 1
	Next
Hi Jhoel
can you help me to convert this part of the code to VBA? I have managed to change everything else to make it work in VBA except this part. I appreciate if you can help me with this.
Ali
Signature_Small
Message 8 of 14
william
Perfect this is exactly what I need.
There are a lot of threads on this forum saying it is not possible to export dxf with text.
In my instance I am exporting named faces to dxf and the parts are a mix of sheet metal and standard parts, so I can't use the flat pattern export. This is a nice solution.
One question I had.. what is the below text formatting and where do I get info on this? Is all of this necessary?
	& vbNewLine & "0" _
	& vbNewLine
	& vbNewLine & "0" _
	& vbNewLine
Second question is the line
Just curious where these values came from.
Many thanks
Message 9 of 14
Ralf_Krieg
Hello
The statement that it is not possible to export text with dxf is correct. The code adds the text afterwards by writing direct in the exported dxf file.
The required text comes from the dxf reference definition of a text entity. You can view the reference online for instance here: https://documentation.help/AutoCAD-DXF/
Check the Chapter TEXT in ENTITIES.
The RegEx, if I understand it right, searches for the first string "ENDDESC" after the string "ENTITIES" and returns the position right before the "ENDDESC" string. At that position the RealTextToAdd value is inserted. I'm not sure why running in a loop, cause dxf should have only one ENTITIES section, so there could only be one match. *???*
R. Krieg
RKW Solutions GmbH
www.rkw-solutions.com
Message 10 of 14
william
in reply to: Ralf_Krieg
Thanks. @Ralf_Krieg
I had the same issue as @Anonymous with the positioning of the text within the dxf, particularly exporting faces not aligned to the UCS.
What I found to work was reading through the dxf file afterwards, adding the vector points to an array, and calculating text positioning off of that.
Sub Main
dxfFilename = "your file.dxf"
SearchTerm = "AcDb2dVertex"
Dim ReadFile() As String = System.IO.File.ReadAllLines(dxfFilename)
Dim Array_X As New ArrayList
Dim Array_Y As New ArrayList
i = 0
For Each Line As String In System.IO.File.ReadAllLines(dxfFilename)
        If Line.Contains(SearchTerm) Then
        'MessageBox.Show("Line no. " & ReadFile(i), "Title")
		'MessageBox.Show("X = " & ReadFile(i + 2) & vbNewLine & "Y = " & ReadFile(i + 4), "Title")
		Array_X.Add(CInt(ReadFile(i + 2)))
		Array_Y.Add(CInt(ReadFile(i + 4)))
    End If
	i = i + 1
Next
Array_X.Sort()
Array_Y.Sort()
minX = Array_X(0)
maxX = Array_X(Array_X.Count-1)
minY = Array_Y(0)
maxY = Array_Y(Array_X.Count - 1)
PosX = ((maxX - minX) / 2) + minX
PosY = ((maxY - minY) / 2) + minY
'MessageBox.Show("minX = " & minX & vbNewLine & "maxX = " & maxX & vbNewLine & "minY = " & minY & vbNewLine & "maxY = " & maxY, "Title")
''Error Checking code - to see what the array values are
'oWrite = System.IO.File.CreateText(ThisDoc.PathAndFileName(False) & ".txt")
'For i = 0 To Array_X.Count - 1
'	oWrite.WriteLine("Array_X(" & i & ") = " & Array_X(i))
'Next
'For i = 0 To Array_Y.Count - 1
'	oWrite.WriteLine("Array_Y(" & i & ") = " & Array_Y(i))
'Next
'oWrite.Close()
'ThisDoc.Launch(ThisDoc.PathAndFileName(False) & ".txt")
Call EditDXFFile("Text Line 1", PosX, PosY, dxfFilename, "1D5")
Call EditDXFFile("Text Line 2", PosX, PosY - 5, dxfFilename, "1D6")
End Sub
Sub EditDXFFile(TextToAdd As String, PosX As Double, PosY As Double, dxfFilename As String, IDnumber As String)
	& vbNewLine & "0" _
	& vbNewLine
	& vbNewLine & "0" _
	& vbNewLine
	Dim readText As String = System.IO.File.ReadAllText(dxfFilename)
		readText = readText.Insert(match.Index + textLen * m, realTextToAdd)
		m = m + 1
	Next
	System.IO.File.WriteAllText(dxfFilename, readText)
End Sub
Message 11 of 14
jaimin.ja.3
Hey, @JhoelForshav thank you for sharing this code it works perfectly.
please find attached photos,
1. Notch at bend and marking lines = is it possible to add notch at both end of the marking line so that bender can easily match notch with die & need to reduce the size of bend line so we can reduce time of laser cutting and marking. ( 2nd option is add notch at only down bend line or optional)
2. file rename - if qty is mentioned in file name? (most of nesting software can read the file name formats & file saving structure, now if quantity is mentioned in file name then we don't need to add manually and it will gives precise cutting file qty and reduce time.
Message 12 of 14
Maxim-CADman77
in reply to: william
Even so the thread is not new... I believe it worth to continue discussing note position control
Dear @william
The code you've shared doesn't work for me (and the post have no single "like").
Moreover none of DXFs exported from Inventor by means of the rule from solution-post contains "AcDb2dVertex" (there is even neither "AcDb2" nor "Vertex") ...
Most often "AcDb"-starting text-lines are "AcDbEntity" and "AcDbLine"...
Message 13 of 14
william
in reply to: Maxim-CADman77
Hello Maxim
You can find out more about the AcDb2dVertex class here.
AutoCAD 2023 for Mac Developer and ObjectARX Help | AcDb2dVertex | Autodesk
I did a quick test, exporting a face to dxf from inventor of a simple cube part, and a sheet metal flat pattern.
It seems as though the flat pattern doesn't use the AcDb2dVertex but rather AcDbLine instead. The export dxf for a selected face however does contain the AcDb2dVertex.
In my case, I am exporting named faces or surface bodies not flat patterns, so it works for me, but it seems as though there are some differences with the different commands.
Dim oCtrlDef As ButtonDefinition
Set oCtrlDef = ThisApplication.CommandManager.ControlDefinitions.Item("GeomToDXFCommand")
oCtrlDef.Execute
You would have to modify the code to make this work for a sheet metal flat pattern.
Message 14 of 14
Dear @JhoelForshav
Don't you know how to set some custom color of the text added in the way you've shared (either change color of the 0 layer or add the text to some custom layer with custom color)?
Thank you in advance.
Technology Administrators
