I made an iLogic rule which iterates through each of the components within an assembly and switches the design view to "Default" but when I attempt to run the rule in a weldment it errors out with "The parameter is incorrect. (Exception from HRESULT: 0x80070057 (E_INVALIDARG))". I have tested the code in a normal assembly and it performs as I had expected.
I still have to add coding to add "Default" in event it doesn't exist but I want to first solve this error.
When I look at the logger for the information I requested I notice it is looking at the weldment itself as an occurrence, then attempts to set the design view then errors out. Is this being done because it is a weldment?
The code I am using is below and I have added a test weldment.
Dim oAssyDoc As AssemblyDocument oAssyDoc = ThisApplication.ActiveDocument Dim oAssyCompDef As ComponentDefinition oAssyCompDef = oAssyDoc.ComponentDefinition Dim oOccurrences As ComponentOccurrences oOccurrences = oAssyCompDef.Occurrences Dim oOcc As ComponentOccurrence For Each oOcc In oOccurrences Logger.Info(oOcc.DefinitionDocumentType) If oOcc.DefinitionDocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then Logger.Info(oOcc.BOMStructure) Logger.Info(oOcc.Name) oOcc.SetDesignViewRepresentation("Default", , True) Logger.Info("Confirm If") End If Next
Solved by JelteDeJong. Go to Solution.
Your assumption that welds are seen as occurrences is correct. You can skip the welds like this:
Dim oAssyDoc As AssemblyDocument = ThisDoc.Document
Dim oAssyCompDef As ComponentDefinition = oAssyDoc.ComponentDefinition
Dim oOccurrences As ComponentOccurrences = oAssyCompDef.Occurrences
For Each oOcc As ComponentOccurrence In oOccurrences
If (oOcc.Definition.Type = ObjectTypeEnum.kWeldsComponentDefinitionObject) Then
Dim weldOccDefinition As WeldsComponentDefinition = oOcc.Definition
' This is impossible ;-)
' weldOccDefinition.SetDesignViewRepresentation("Default", , True)
MsgBox("Found a weld lets continue to the next oOcc")
Continue For
End If
logger.Info(oOcc.DefinitionDocumentType)
logger.Info(oOcc.BOMStructure)
logger.Info(oOcc.Name)
logger.Info("Confirm If")
End If
Next
Jelte de Jong
Blog: hjalte.nl - github.com
Continue For
End If
End If
Next
Jelte de Jong
Thanks for the help!
