Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Showing results forĀ
Did you mean:Ā
Set Kfactor iLogic
3 REPLIES 3
johnster100
1168 Views, 3 Replies
Set Kfactor iLogic
Hi Guys,
Is there an easy way to set Kfactor is sheet metal parts using iLogic or API. There's a command get Kfactor but nothing there to set it.
thanks,
John
Tags (3)
3 REPLIES 3
Take a look in the API Help Files, there are the following properties:
FlatBendResult.kFactor Property
UnfoldMethod.kFactor Property
I hope it helps,
Philippe.
Philippe Leefsma
Developer Technical Services
Autodesk Developer Network
204Š•10
in reply to: johnster100
I have the same question I have created the ilogi lines shown below, but are unfinish any help?:
Sub oKFactor()
doc = ThisDoc.Document
Dim aOa As String
oSDef = doc.ComponentDefinition
For Each oEachMethod In oSDef.UnfoldMethods
If oEachMethod.UnfoldMethodType = UnfoldMethodTypeEnum.kLinearUnfoldMethod Then
Select Case iProperties.Value("Project", "Material")
Case "ALUMINIUM"
oEachMethod.kFactor = "0.50"
Case "MILD/ST"
oEachMethod.kFactor = "0.44"
Case "ST/ST (304L)"
oEachMethod.kFactor = "0.36"
Case Else
End Select
End If
Next
kFactor = SheetMetal.ActiveKFactor
MessageBox.Show(kFactor , "K Factor")
End Sub
YuhanZhang
in reply to: 204Š•10
The iLogic rule should work, I just tested it here if I  set the document material to one of that in your Select Case, it does update the kFactor's value.
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Technology Administrators
