Hello guys,
at first i want to excuse my english since im not a native speaker, but I do my best to be understandable.
I'm looking for an opportunity to implement automated hole dimensions in my drawings, but i want to differ whether its a clearance hole (don't know if its the right word) or a threaded one.
For example I have a drilled hole plate (same with that word) with holes Ø8,5 which are for M8 screws, Ø8 which i want to specify as Ø8H7 and M8 holes. I want to create some code, that for example looks out for every Ø8mm hole, collect them and dimension them as "Ø8H7", but only them, same also for the M8 holes (I think i need to hide the actual dimension there).
I already watched out for solutions, I think a selectionset could be an option, but I don't know how to use them and I only found solutions where the holes were picked manually.
If there is anyone that has a solution for this kind of problem, I'd appreciate it a lot.
I'm using the Inventor 2020.
Thank you in advance!
