Hi There,
My end goal is to have a very simple form either being a user form, ilogic form or fully coded custom form that with a button similar to the select objects button in some feature forms that would allow me to select one or more objects depending on the task and output there names next to it if necessary. Also allowing if you mistakenly click an object and want to reselect you just simply press said button to clear selection and reselect. I understand the pick function but I can't seem to find any sort of button or how to assign it to said buttons event in a form.
Hi Noah, nice to meet you.
I don't know if it is exactly what you want to do, but in an ilogic form you can add rules as buttons, in this way within a rule you can have the code to select the elements and add said rule as a button in your form.
