- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm trying to write code to display the hidden curves for a specific component occurrence. I've seen people that are doing similar by finding the occurrence in the assembly tree. I'm struggling with this a bit as it's quite a complicated drawing with lots of different types of view (sections, details etc) so locating the node can be tricky.
I was wondering if it's possible to select 'a body' in a drawing view from one of it's drawing curves (similar to select Body in the filters option) as I can very easily get the drawing curves for a specific view.
So far I have not managed to find a way to do this.
Once I've done this I can run the control definition option for showing hidden curves and my code will work as intended.
thanks,
John
