Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Hey everyone! I needed a quick way to work with parameters and had a bit of time to put this together. I'm sharing the script here — hopefully, it'll be useful to someone!
Description:
This VB iLogic script for Autodesk Inventor allows users to view, edit, and add named or renamed standard parameters in the active document, with all values displayed in millimeters. The interface is built using Windows Forms and WebBrowser, providing an intuitive way to manage parameters interactively. The script supports parameter sorting, saving user preferences (theme, language, window position), and switching between light and dark interface themes. Users can quickly close the window using keyboard shortcuts, and it is recommended to assign a hotkey for fast access to the script.
Key Features:
View and Edit Named/Renamed Standard iProperty Parameters:
Millimeter-based Values:
Parameter Sorting:
Interface Themes:
Multi-language Support:
Save User Settings:
Window Closing Keys:
Recommended Usage:
For quicker access, it is recommended to assign a hotkey to this script in the iLogic environment, allowing you to open it instantly whenever needed. This greatly speeds up workflows when managing parameters frequently.
Application:
This script is ideal for Autodesk Inventor users who work with standard iProperty parameters that have been named or renamed. It provides quick access to manage these parameters in millimeters, offering a streamlined solution for parameter management.
Example of Usage:
How to Install:
Technical Requirements:
Note on Development:
This script was fully developed with the help of ChatGPT-4o, o1-preview, o1-mini, and Claude 3.5 Sonnet, leveraging advanced AI models to streamline the creation process and ensure a robust and intuitive user experience.
good job, I like it, thanks for your share
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
如果我的回帖解决了您的问题,请点击 "接受为解决方案" 按钮. 这可以帮助其他人更快的找到解决方案!
王 承之
Autodesk AGN [Inventor 俱乐部] Leader
Inventor Club | Bilibili
