I need to save all of my IDW files to DWG format for my customers. When I do this I loose the colors and blocks. Does anyone have a plug in or macro that would fix this problem?
Can you explain more about the problem? Do you save the IDW to Inventor DWG or AutoCAD DWG? And can you provide a data sample to reproduce the color&block missing issue?
I need to save the files to an Autocad 2010 format. I need the files to maintain color and create blocks so the files can be worked with by my customers. When I save the IDW files to and Autocad file they are all white in color and the blocks are limited to geometry and title block. With the large assemblies I need the files to be more functional.
Can you try to use the DWG File Export Options when save the IDW to AutoCAD DWG to check if it can solve the problems? The API does not do anything more than the UI functions.
As Rocky mentioned, the API has no more functionalities than the UI, so you should first check if that's doable from UI. If not, you will have to process the dwg either with AutoCAD API or RealDWG.
Here is a sample that illustrates how to retrieve all export options for the DWG translator:
Public Sub GetTranslatorSaveAsOptions() Dim clsId As String clsId = "{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}" Dim oTranslator As TranslatorAddIn Set oTranslator = ThisApplication.ApplicationAddIns.ItemById(clsId) Dim Context As TranslationContext Set Context = ThisApplication.TransientObjects.CreateTranslationContext Context.Type = kFileBrowseIOMechanism Dim options As NameValueMap Set options = ThisApplication.TransientObjects.CreateNameValueMap Dim sourceObject As Object Set sourceObject = ThisApplication.ActiveDocument Dim index As Integer If oTranslator.HasSaveCopyAsOptions(sourceObject, Context, options) Then For index = 1 To options.count Debug.Print options.Name(index) & " = " & options.value(options.Name(index)) Next End If End Sub
This is the output of that code:
Publish_All_Sheets = 0 Publish_3D_Models = 0 Launch_Viewer = 0 Password = Publish_Mode = 62721 Enable_Large_Assembly_Mode = 0 Enable_Measure = 1 Enable_Printing = 1 Enable_Markups = 1 Enable_Markup_Edits = 1 Output_Path = Include_Sheet_Tables = 1 Sheet_Metal_Flat_Pattern = 0 Sheet_Metal_Style_Information = 0 Sheet_Metal_Part = 1 Weldment_Preparation = 0 Weldment_Symbol = 0 BOM_Structured = 1 BOM_Parts_Only = 1 Animations = 0 Instructions = 0 iAssembly_All_Members = 0 iAssembly_3D_Models = 0 iPart_All_Members = 0 iPart_3D_Models = 0 Publish_Component_Props = 1 Publish_Mass_Props = 1 Include_Empty_Properties = 0 Publish_Screenshot = 0 Screenshot_DPI = 96 Facet_Quality = 69379 Force_Facet_Recompute = 0 Facet_Recompute_Tolerance = 0.001 Override_Sheet_Color = 0 Sheet_Color = 0 Sheet_Range = 14081 Custom_Begin_Sheet = 1 Custom_End_Sheet = -1 All_Color_AS_Black = 0 Remove_Line_Weights = 0 Vector_Resolution = 400 TranscriptAPICall = 0
And here an example from the help files on how to use options with PDF translator:
Public Sub PublishPDF() ' Get the PDF translator Add-In. Dim PDFAddIn As TranslatorAddIn Set PDFAddIn = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}") 'Set a reference to the active document (the document to be published). Dim oDocument As Document Set oDocument = ThisApplication.ActiveDocument Dim oContext As TranslationContext Set oContext = ThisApplication.TransientObjects.CreateTranslationContext oContext.Type = kFileBrowseIOMechanism ' Create a NameValueMap object Dim oOptions As NameValueMap Set oOptions = ThisApplication.TransientObjects.CreateNameValueMap ' Create a DataMedium object Dim oDataMedium As DataMedium Set oDataMedium = ThisApplication.TransientObjects.CreateDataMedium ' Check whether the translator has 'SaveCopyAs' options If PDFAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then ' Options for drawings... oOptions.Value("All_Color_AS_Black") = 0 'oOptions.Value("Remove_Line_Weights") = 0 'oOptions.Value("Vector_Resolution") = 400 'oOptions.Value("Sheet_Range") = kPrintAllSheets 'oOptions.Value("Custom_Begin_Sheet") = 2 'oOptions.Value("Custom_End_Sheet") = 4 End If 'Set the destination file name oDataMedium.FileName = "c:\temp\test.pdf" 'Publish document. Call PDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium) End Sub
Hope that helps,
Philippe.
