Message 1 of 21
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am not an ilogic programmer (yet), I am just starting to learn. I copied this code from 2 different sources but I'm having a problem with the sheet number. It's saving with a 2 in the filename, but I do not understand where it is pulling this from especially when running the rule from sheet 1, as it should be a 1 not a 2. All other properties are appearing in filename correctly, except the sheet number.
PDF filename: Project Number-Part Number-Sheet Number Description.pdf (Ex: S2100-A100-1 Tail Frame.pdf)
I know you guys are the experts, any help would be greatly appreciated. Thanks.
Here is the code:
oPath = ThisDoc.Path oFileName = ThisDoc.FileName(False) 'without extension oRevNum = iProperties.Value("Project", "Revision Number") oPDFAddIn = ThisApplication.ApplicationAddIns.ItemById _ ("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}") oDescription = iProperties.Value("Project", "Description") oPartNumber = iProperties.Value("Project", "Part Number") oProject = iProperties.Value("Project", "PROJECT") oDocument = ThisApplication.ActiveDocument oContext = ThisApplication.TransientObjects.CreateTranslationContext oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism oOptions = ThisApplication.TransientObjects.CreateNameValueMap oDataMedium = ThisApplication.TransientObjects.CreateDataMedium oDoc = ThisDoc.Document ' Define folder browse dialog Dim Dialog = New FolderBrowserDialog() Dialog.SelectedPath = "T:\ENG 3D\JOBS" Dialog.ShowNewFolderButton = True Dialog.Description = "Choose Folder for Export..." If DialogResult.OK = Dialog.ShowDialog() Then ExportPath = Dialog.SelectedPath & "\" Else Exit Sub End If 'Define the drawing Dim oDrawing As DrawingDocument oDrawing = ThisDoc.Document Dim oSheet As Sheet Dim lPos As Long Dim rPos As Long Dim sLen As Long Dim sSheetName As String Dim iSheetNumber As Integer 'step through each drawing sheet For Each oSheet In oDrawing.Sheets 'find the seperator in the sheet name:number lPos = InStr(oSheet.Name, ":") 'find the number of characters in the sheet name sLen = Len(oSheet.Name) 'find the sheet name sSheetName = Left(oSheet.Name, lPos -1) 'find the sheet number iSheetNumber = Right(oSheet.Name, sLen - lPos) Next 'set PDF Options If oPDFAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then oOptions.Value("All_Color_AS_Black") = 1 oOptions.Value("Remove_Line_Weights") = 1 oOptions.Value("Vector_Resolution") = 400 oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintSheetRange oOptions.Value("Custom_Begin_Sheet") = iSheetNumber oOptions.Value("Custom_End_Sheet") = iSheetNumber End If If iProperties.Value("Project", "Revision Number") >= "1" Then ExportPath = ExportPath End If oDataMedium.FileName = ExportPath & oProject & "-" & oPartNumber & "-" & iSheetNumber & " " & oDescription & ".pdf" Try oPDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium) ' Ask the user if he/she wants to open the file question2 = MessageBox.Show("Open PDF file?", "PDF Created",MessageBoxButtons.YesNo,MessageBoxIcon.Question) If question2 = vbYes Then ThisDoc.Launch(oDataMedium.FileName) End If Catch MessageBox.Show("PDF not created, document may be open.", "Please close and try again ") End Try Exit Sub
Victoria
