Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Save as jpeg
Save as jpeg
tomislav.peran
Save as jpeg
tomislav.peran
Sometimes If I have an assembly or a part opened I export it as a jpeg file to get a picture of it.
I assume it is possible to do this via code?
Therefore,  1. File -> Export Assembly/Part -> Image -> Jpeg files (.jpg)
                    2. Location: same location where assembly/part is saved.
That code would be really cool to have, so if anyone knows the code, please let me know.
Tom
fullevent
Hi @tomislav.peran,
I made once this function to do exactly that. It's for IPTs but that could be adjusted.
Maybe that will help you 🙂
Private Sub create_jpg(saveName As String)
    Dim oPartDoc As PartDocument
    Set oPartDoc = ThisApplication.ActiveDocument
    Dim oActiveView As View
    Set oActiveView = ThisApplication.ActiveView
    Dim oCamera As Camera
    Set oCamera = oActiveView.Camera
    oCamera.ViewOrientationType = kTopViewOrientation
    oCamera.Apply
    ThisApplication.ActiveView.Fit
    Dim oWorkAxes As WorkAxes
    Set oWorkAxes = oPartDoc.ComponentDefinition.WorkAxes
    oWorkAxes.Item(1).Visible = True
    oWorkAxes.Item(2).Visible = True
    Call oActiveView.SaveAsBitmap(saveName & ".jpg", 1000, 800)
    oWorkAxes.Item(1).Visible = False
    oWorkAxes.Item(2).Visible = False
End Sub
Edit:
To get the saveName I have this line somewhere
Left$(oPartDoc.FullDocumentName, Len(oPartDoc.FullDocumentName) - 4)
Best regards,
Aleksandar Krstic
Produkt- und Projektmanager
tomislav.peran
Hi fullevent,
Thanks for the code. This idea is exactly what I want. 🙂 Top view with axes.
However, I get an error when it wants to save as jpg:
Error on line 16 in rule: Rule0, in document: MyPart.ipt
Klasse is niet geregistreerd
SaveName -> is it the same as the given document name? And will it save it at the same location as part/assy?
I have also removed "set" at the start of the lines. I use code in Inventor and it does not want to have "set" in the code.
Also, It wants me to change Prive Sub to Sub main.
Tom
fullevent
Hi Tom,
didn't know you are trying to create an iLogic.
Try this rule. I just tested it and it works for me.
Dim saveName As String
Dim oDoc As PartDocument
oDoc = ThisApplication.ActiveDocument
oCamera.Apply
saveName = Left$(oDoc.FullDocumentName, Len(oDoc.FullDocumentName) - 4)
The filename contains the full path. Therefor it will safe the jpg at same location and same name as the assembly/part.
Greetings,
Aleksandar Krstic
tomislav.peran
Hi fullevent,
Works perfect. Thank you a lot!
Tom
fullevent
Greate, you're welcome 🙂
Aleksandar Krstic
