How would I have logic take a decimal number and round it up to the next whole number
Solved by dutt.thakar. Go to Solution.
You can do that without iLogic also if you are trying to do it in parameters. See below link which describes various functions that parameters can support,
In a nutshell, Ceil (Roundup), Floor(round down), and Round(To nearest value, either up or down)
If you are thinking to go only the iLogic way, you can go to snippets and check the "Math" group, where you will find all the different functions that can be used. see the below snap for more details.
