Revision Reminder
Revision Reminder
Revision Reminder
I am looking for the iLogic code that would remind me on save if i forgott to populate revision number in Iproperties.(Blank revision property = massage box?)
I would like to implement this  rule in my template ( parts and assemblies).
Ok guys I have gound the code that working perfect:
'start of iLogic Code-----------------------------
'declare variables
'get the user name from the Inventor Options
myName= ThisApplication.GeneralOptions.UserName
'get the iProperty Description Field
Revision = iProperties.Value("Project", "Revision Number")
'create a message for the user
mymessage = (myname & ",  you forgot to fill out the Revision property again.")
'check the iProperty Description Field to see if it is empty
If Revision = "" Then
'display a message box
MessageBox.Show(mymessage, "Revision Reminder")
'end of iLogic Code-----------------------------
humbertogo
Check for empty Properties with before save event
yvandelafontaine
An even Easier and faster way of doing this would be to create a form in your template called "REV_REMINDER"
in it drag your revision field from properties tab.
then change your code to this:
'Start of iLogic Code---------------------------
iLogicForm.Show("REV_REMINDER")
Else
'Do Nothing
Whenever your rev is not filled out it will pop a dialog box where you can set your revision without having to go into properties, set it to run before save as the previous user mentionned
