I keep developing a rule to retrieve following data (recorded in a notepad document):
for each occurrence in the assembly (which is the main erection assembly usually) under consideration.
Data may appear as Parent @ BOM Structure @ Full File Name @ sign is just delimiter.
I still keep doing by myself - Thought getting help because I may not succeed (whatever time I spend).
I request help.
Solved by Sergio.D.Suárez. Go to Solution.
Hi, following another statement about recognizing the father of a component, I write another statement, maybe I can help you, I have not checked it completely. It is a question of looking for all the reference files of an assembly and looking for the father of these files (it does not look for occurrences) this is a simple proposal to test it in a small assembly.
Dim openDoc As Document openDoc = ThisDoc.Document Dim doc As Document For Each doc In openDoc.AllReferencedDocuments Dim Parent As Document = doc.ReferencingDocuments.Item(1) BOM_X = Parent.componentdefinition.BOMStructure If BOM_X = BOMStructureEnum.kDefaultBOMStructure Then BOM_Structure = "Default" If BOM_X = BOMStructureEnum.kNormalBOMStructure Then BOM_Structure = "Normal" If BOM_X = BOMStructureEnum.kPhantomBOMStructure Then BOM_Structure = "Phantom" If BOM_X = BOMStructureEnum.kReferenceBOMStructure Then BOM_Structure = "Reference" If BOM_X = BOMStructureEnum.kPurchasedBOMStructure Then BOM_Structure = "Purchased" If BOM_X = BOMStructureEnum.kInseparableBOMStructure Then BOM_Structure = "Inseparable" If BOM_X = BOMStructureEnum.kVariesBOMStructure Then BOM_Structure = "Varies" MessageBox.Show(doc.displayname & ": " & Parent.DisplayName & "@" & BOM_Structure, "Title") Next
Modified for your particular use would be something like this
Public Class RWEI_0007BOM Shared oTextSave As String = "C:\Users\Public\Documents\iLogicBuffer.txt" Sub Main Dim oAssy_ThisDoc As AssemblyDocument Dim oDoc As Document = ThisApplication.ActiveDocument Dim iL_NO As String = "0002-BOM" oDelete_ex_Notepad(oTextSave, iL_NO) Dim HL1_Prefix As String = "FILE REFERENCE TREE RAN FROM: " oHL1 = HL1_Prefix & oDoc.FullFileName oWrite_HeaderLines(oTextSave, oHL1) Dim iL_Name As String = "All Occurrences with BOM Structure" Dim oHL2 As String = "Rule " & iL_NO & ": " & iL_Name oWrite_HeaderLines(oTextSave, oHL2) Dim oDashes As String = "" For i = 1 To Len(oHL2) oDashes = oDashes & "-" Next i Dim oHL3 As String = oDashes oWrite_HeaderLines(oTextSave, oHL3) Dim oHL4 As String = "" oWrite_HeaderLines(oTextSave, oHL4) Dim oName_Parent As String Dim oAsmCompDef As AssemblyComponentDefinition oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition Dim doc As Document For Each doc In oDoc.AllReferencedDocuments oFFN_X = doc.FullFileName Dim Parent As Document = doc.ReferencingDocuments.Item(1) BOM_X = Parent.componentdefinition.BOMStructure If BOM_X = BOMStructureEnum.kDefaultBOMStructure Then BOM_Structure = "Default" If BOM_X = BOMStructureEnum.kNormalBOMStructure Then BOM_Structure = "Normal" If BOM_X = BOMStructureEnum.kPhantomBOMStructure Then BOM_Structure = "Phantom" If BOM_X = BOMStructureEnum.kReferenceBOMStructure Then BOM_Structure = "Reference" If BOM_X = BOMStructureEnum.kPurchasedBOMStructure Then BOM_Structure = "Purchased" If BOM_X = BOMStructureEnum.kInseparableBOMStructure Then BOM_Structure = "Inseparable" If BOM_X = BOMStructureEnum.kVariesBOMStructure Then BOM_Structure = "Varies" oName_Parent = Parent.DisplayName & "@" & BOM_Structure & "@" & oFFN_X oWrite_Data(oTextSave, oName_Parent) Next Process.Start("Notepad.exe", oTextSave) End Sub Sub oWrite_HeaderLines(oTextSave As String, oHeaderLine As String) oWrite = System.IO.File.AppendText(oTextSave) oWrite.WriteLine(oHeaderLine) oWrite.Flush() oWrite.Close End Sub Sub oWrite_Data(oTextSave As String, oData As String) oWrite = System.IO.File.AppendText(oTextSave) oWrite.WriteLine(oData) oWrite.Flush() oWrite.Close End Sub Sub oDelete_ex_Notepad(oTextSave As String, iL_NO As String) 'To delete oTextSave if existing. If System.IO.File.Exists(oTextSave) = True Then System.IO.File.Delete(oTextSave) End If End Sub End Class
I hope it works for you and you can try it. To tell the truth, it is very nice to be able to share ideas with you, I am not an expert or anything like that, I am a simple self-taught person who has learned a lot from your contributions, that is why I feel indebted to you for a long time. regards
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
I like both of the codes provided. The top one is fine because it gives all the unique documents of the assembly (good for tracking all the drawings to be issued).
Still the first solution (in your 1st posting) you provided is fine because it displays all the occurrences (i.e. what we really see in the assembly) where we can find the quantities and retrieve the BOM structure as well.
In this regard, (retrieving the BOM structure) I have an issue. Documents with reference BOM structure assigned in the assembly level, still indicate the default. I am sorry to ask you this, but could you take a kook at this as well?
Thanks.
I've checked it. I think the problem is here. The rule shows you the property of the list of materials that is accessed through the document settings, read what I show you below
Now if you change this property from assembly, as I show you next, it will not reflect the change because the change does not do it at the document level, it does it at the assembly level
This may be due to the fact that one could have an assembly that could use it several times, and only one of them is a reference for example (then the property of the assembly document would not be a reference). I suppose then that the structure of the rule is fine in your models (that is, it reads the property correctly only we need to read it from another place), maybe we should access the property from a higher level than the occurrence
What do you think about it?
Mechanical Designer
I agree with you.
While I was testing with several sample models, once I saw it the Bom Structure reflecting the BOM assigned in the assembly: I soon lost my work and hard to think what/how was it. I will let you know if I come across with it again.
I need it because I can't deduce accurate results from my exported list.
I have not yet been able to solve the whole problem but I have found something that I wanted to share with you. I have accessed the structure of the Bom, from the list of materials "Model data" from the assembly. It's still incomplete but maybe it's a new path. With this method, a piece can be a reference in the assembly and at the same time it can not be a reference in the properties of the document. Then when you load the list you will put it as reference as appropriate.
The initial base code to search for that stretch is this applied to a small assembly
Dim oBOM As BOM oBOM = ThisApplication.ActiveDocument.ComponentDefinition.BOM Dim oBOMView As BOMView oBOMView = oBOM.BOMViews.Item("Unnamed")'Accesing to Model data Column "Unnamed" Dim oBOMRow As BOMRow For Each oBOMRow In oBOMView.BOMRows 'Set a reference to the primary ComponentDefinition of the row Dim oBOMStructnumber As String oBOMStructnumber = oBOMRow.BOMStructure Dim oBOMStruct As String If oBOMStructnumber = 51969 Then oBOMStruct = "The Default Structure Type" If oBOMStructnumber = 51974 Then oBOMStruct = "The inseparable Structure Type" If oBOMStructnumber = 51970 Then oBOMStruct = "The normal Structure Type" If oBOMStructnumber = 51971 Then oBOMStruct = "The phantom Structure Type" If oBOMStructnumber = 51973 Then oBOMStruct = "The purchased Structure Type" If oBOMStructnumber = 51972 Then oBOMStruct = "reference Structure Type" If oBOMStructnumber = 51975 Then oBOMStruct = "The Structure Type varies amongst references" Dim oDef As ComponentDefinition oDef = oBOMRow.ComponentDefinitions(1) Dim oFileName As String oFileName = oDef.Document.Displayname'PropertySets("{32853F0F-3444-11D1-9E93-0060B03C1CA6}")("Part Number").value MessageBox.Show(oFileName & "->" & oBOMStruct, "Title") Next
and accommodating it a bit, but not fulfilling all your goals
Public Class RWEI_0007BOM Shared oTextSave As String = "C:\Users\Public\Documents\iLogicBuffer.txt" Sub Main Dim oAssy_ThisDoc As AssemblyDocument Dim oDoc As Document = ThisApplication.ActiveDocument Dim iL_NO As String = "0002-BOM" oDelete_ex_Notepad(oTextSave, iL_NO) Dim HL1_Prefix As String = "FILE REFERENCE TREE RAN FROM: " oHL1 = HL1_Prefix & oDoc.FullFileName oWrite_HeaderLines(oTextSave, oHL1) Dim iL_Name As String = "All Occurrences with BOM Structure" Dim oHL2 As String = "Rule " & iL_NO & ": " & iL_Name oWrite_HeaderLines(oTextSave, oHL2) Dim oDashes As String = "" For i = 1 To Len(oHL2) oDashes = oDashes & "-" Next i Dim oHL3 As String = oDashes oWrite_HeaderLines(oTextSave, oHL3) Dim oHL4 As String = "" oWrite_HeaderLines(oTextSave, oHL4) Dim oBOM As BOM oBOM = ThisApplication.ActiveDocument.ComponentDefinition.BOM Dim oBOMView As BOMView oBOMView = oBOM.BOMViews.Item("Sin nombre")'Accesing to Model data Column 'In English__"Unnamed"_"Structured"_"Parts Only"__In Spanish__"Sin nombre"_"Estructurado"_"Solo piezas" For Each oBOMRow In oBOMView.BOMRows 'Set a reference to the primary ComponentDefinition of the row Dim oBOMStructnumber As String oBOMStructnumber = oBOMRow.BOMStructure Dim BOM_Structure As String If oBOMStructnumber = 51969 Then BOM_Structure = "The Default Structure Type" If oBOMStructnumber = 51974 Then BOM_Structure = "The inseparable Structure Type" If oBOMStructnumber = 51970 Then BOM_Structure = "The normal Structure Type" If oBOMStructnumber = 51971 Then BOM_Structure = "The phantom Structure Type" If oBOMStructnumber = 51973 Then BOM_Structure = "The purchased Structure Type" If oBOMStructnumber = 51972 Then BOM_Structure = "reference Structure Type" If oBOMStructnumber = 51975 Then BOM_Structure = "The Structure Type varies amongst references" Dim oDef As ComponentDefinition oDef = oBOMRow.ComponentDefinitions(1) Dim oFFN_X As String oFFN_X = oDef.Document.Displayname Dim oDocFile As Document oDocFile = oDef.Document Dim Parent As Document = oDocFile.ReferencingDocuments.Item(1) oName_Parent = Parent.DisplayName & "@" & BOM_Structure & "@" & oFFN_X oWrite_Data(oTextSave, oName_Parent) Next Process.Start("Notepad.exe", oTextSave) End Sub Sub oWrite_HeaderLines(oTextSave As String, oHeaderLine As String) oWrite = System.IO.File.AppendText(oTextSave) oWrite.WriteLine(oHeaderLine) oWrite.Flush() oWrite.Close End Sub Sub oWrite_Data(oTextSave As String, oData As String) oWrite = System.IO.File.AppendText(oTextSave) oWrite.WriteLine(oData) oWrite.Flush() oWrite.Close End Sub Sub oDelete_ex_Notepad(oTextSave As String, iL_NO As String) 'To delete oTextSave if existing. If System.IO.File.Exists(oTextSave) = True Then System.IO.File.Delete(oTextSave) End If End Sub End Class
Mechanical Designer
Following with attempts here you have another sample, surely it needs to retouch, but it can be a favorable way, you can place the quantities to each piece or component, you have to keep investigating
Public Class RWEI_0007BOM Shared oTextSave As String = "C:\Users\Public\Documents\iLogicBuffer.txt" Sub Main Dim oAssy_ThisDoc As AssemblyDocument Dim oDoc As Document = ThisApplication.ActiveDocument Dim iL_NO As String = "0002-BOM" oDelete_ex_Notepad(oTextSave, iL_NO) Dim HL1_Prefix As String = "FILE REFERENCE TREE RAN FROM: " oHL1 = HL1_Prefix & oDoc.FullFileName oWrite_HeaderLines(oTextSave, oHL1) Dim iL_Name As String = "All Occurrences with BOM Structure" Dim oHL2 As String = "Rule " & iL_NO & ": " & iL_Name oWrite_HeaderLines(oTextSave, oHL2) Dim oDashes As String = "" For i = 1 To Len(oHL2) oDashes = oDashes & "-" Next i Dim oHL3 As String = oDashes oWrite_HeaderLines(oTextSave, oHL3) Dim oHL4 As String = "" oWrite_HeaderLines(oTextSave, oHL4) Dim oBOM As BOM oBOM = ThisApplication.ActiveDocument.ComponentDefinition.BOM Dim oBOMView As BOMView oBOMView = oBOM.BOMViews.Item("Unnamed")'Accesing to Model data Column 'In English__"Unnamed"_"Structured"_"Parts Only"__In Spanish__"Sin nombre"_"Estructurado"_"Solo piezas" Call ListItems(oBOMView.BOMRows, 0) Process.Start("Notepad.exe", oTextSave) End Sub Sub ListItems(Rows As BOMRowsEnumerator, indent As Integer) Dim oBOMRow As BOMRow For Each oBOMRow In Rows Dim oBOMStructnumber As String oBOMStructnumber = oBOMRow.BOMStructure Dim BOM_Structure As String If oBOMStructnumber = 51969 Then BOM_Structure = "The Default Structure Type" If oBOMStructnumber = 51974 Then BOM_Structure = "The inseparable Structure Type" If oBOMStructnumber = 51970 Then BOM_Structure = "The normal Structure Type" If oBOMStructnumber = 51971 Then BOM_Structure = "The phantom Structure Type" If oBOMStructnumber = 51973 Then BOM_Structure = "The purchased Structure Type" If oBOMStructnumber = 51972 Then BOM_Structure = "reference Structure Type" If oBOMStructnumber = 51975 Then BOM_Structure = "The Structure Type varies amongst references" Dim oDef As ComponentDefinition oDef = oBOMRow.ComponentDefinitions(1) Dim oFFN_X As String oFFN_X = oDef.Document.Displayname Dim oDocFile As Document oDocFile = oDef.Document Dim Parent As Document = oDocFile.ReferencingDocuments.Item(1) If Not oBOMRow.ChildRows Is Nothing Then Call ListItems(oBOMRow.ChildRows, indent + 1) End If oName_Parent = Parent.DisplayName & "@" & BOM_Structure & "@" & oFFN_X oWrite_Data(oTextSave, oName_Parent) Next End Sub Sub oWrite_HeaderLines(oTextSave As String, oHeaderLine As String) oWrite = System.IO.File.AppendText(oTextSave) oWrite.WriteLine(oHeaderLine) oWrite.Flush() oWrite.Close End Sub Sub oWrite_Data(oTextSave As String, oData As String) oWrite = System.IO.File.AppendText(oTextSave) oWrite.WriteLine(oData) oWrite.Flush() oWrite.Close End Sub Sub oDelete_ex_Notepad(oTextSave As String, iL_NO As String) 'To delete oTextSave if existing. If System.IO.File.Exists(oTextSave) = True Then System.IO.File.Delete(oTextSave) End If End Sub End Class
Mechanical Designer
This is an excellent solution: able to extract occurrence local file name, BOM structure of occurrence where reference BOM structure at assembly is captured and parent of the occurrence.
With this an Excel-Pro can extract all the information required to track the product documentation for manufacturing: good for very large assemblies. (as I am going to do)
Thanks to
Roy Wickrama
Inventor Professional 2019
Vault Professional 2019
Solidworks Professional 2018
Mathcad Prime 5.0
Attached here to is the revised code (to exclude all content center and library parts):
If oDocFile.IsModifiable = True Then
finally;
oName_Parent = Parent.DisplayName & "@" & BOM_Structure & "@" & oFFN_X oWrite_Data(oTextSave, oName_Parent) End If
All content center and library parts excluded
Hi Yuvilo;
For phantom sub-assemblies need parent, parent of parent, etc until the parent is of non-phantom BOM structure
Please don't mind for reverting back to you for help. I further developed the rule to function as shown below:
I have some parts with multiple phantom parents and normal parents. If the parent of a document (part) is of phantom BOM structure, the true parent is the parent of parent and so on until the parent the parent of normal BOM structure is hit.
From my side, if I know the prent of parent, I can get around this issue (at the bottom of this rule). But, it looks like a lot to do!
Could you help, please. Thanks.
Public Class RWEI_0010BOM Shared oTextSave As String = "C:\Users\Public\Documents\iLogicBuffer.txt" Sub Main Dim oAssy_ThisDoc As AssemblyDocument Dim oDoc As Document = ThisApplication.ActiveDocument Dim iL_NO As String = "0010-BOM" oDelete_ex_Notepad(oTextSave, iL_NO) Dim HL1_Prefix As String = "FILE REFERENCE TREE RAN FROM: " oHL1 = HL1_Prefix & oDoc.FullFileName oWrite_HeaderLines(oTextSave, oHL1) Dim iL_Name As String = "All Occurrences with BOM Structure" Dim oHL2 As String = "Rule " & iL_NO & ": " & iL_Name oWrite_HeaderLines(oTextSave, oHL2) Dim oDashes As String = "" For i = 1 To Len(oHL2) oDashes = oDashes & "-" Next i Dim oHL3 As String = oDashes oWrite_HeaderLines(oTextSave, oHL3) Dim oHL4 As String = "" oWrite_HeaderLines(oTextSave, oHL4) Dim oBOM As BOM oBOM = ThisApplication.ActiveDocument.ComponentDefinition.BOM Dim oBOMView As BOMView oBOMView = oBOM.BOMViews.Item("Unnamed")'Accesing to Model data Column 'In English__"Unnamed"_"Structured"_"Parts Only"__In Spanish__"Sin nombre"_"Estructurado"_"Solo piezas" Call ListItems(oBOMView.BOMRows, 0) Process.Start("Notepad.exe", oTextSave) End Sub Sub ListItems(Rows As BOMRowsEnumerator, indent As Integer) Dim oBOMRow As BOMRow For Each oBOMRow In Rows Dim oDef As ComponentDefinition oDef = oBOMRow.ComponentDefinitions(1) Dim oLFN As String oLFN = oDef.Document.Displayname Dim oDocFile As Document oDocFile = oDef.Document If oDocFile.IsModifiable = True Then Dim oBOMStructnumber As String oBOMStructnumber = oBOMRow.BOMStructure Dim BOM_Structure As String If oBOMStructnumber <> 51972 Then If oBOMStructnumber = 51969 Then BOM_Structure = "Default" If oBOMStructnumber = 51974 Then BOM_Structure = "Inseparable" If oBOMStructnumber = 51970 Then BOM_Structure = "Normal" If oBOMStructnumber = 51971 Then BOM_Structure = "Phantom" If oBOMStructnumber = 51973 Then BOM_Structure = "Purchased" If oBOMStructnumber = 51972 Then BOM_Structure = "Reference" If oBOMStructnumber = 51975 Then BOM_Structure = "The Structure Type varies amongst references" ' Dim oDocFile As Document ' oDocFile = oDef.Document ' If oDocFile.IsModifiable = True Then Dim Parent As Document = oDocFile.ReferencingDocuments.Item(1) If Not oBOMRow.ChildRows Is Nothing Then Call ListItems(oBOMRow.ChildRows, indent + 1) End If Dim oPhantomPart_ParentOfPhantomPart As String = "" If Right(oLFN, 3) = "ipt" And BOM_Structure = "Phantom" Then 'Do nothing Else If Right(oLFN, 3) = "iam" And BOM_Structure = "Phantom" Then 'Do nothing Else If Right(oLFN, 3 = "ipt" And BOM_Structure = "Phantom" Then
'oPhantomPart_ParentOfPhantomPart = oLFN & "$" & Parent.DisplayName Else oName_Parent = Parent.DisplayName & "$" & BOM_Structure & "$" & oLFN oWrite_Data(oTextSave, oName_Parent) End If End If End If End If Next End Sub Sub oWrite_HeaderLines(oTextSave As String, oHeaderLine As String) oWrite = System.IO.File.AppendText(oTextSave) oWrite.WriteLine(oHeaderLine) oWrite.Flush() oWrite.Close End Sub Sub oWrite_Data(oTextSave As String, oData As String) oWrite = System.IO.File.AppendText(oTextSave) oWrite.WriteLine(oData) oWrite.Flush() oWrite.Close End Sub Sub oDelete_ex_Notepad(oTextSave As String, iL_NO As String) 'To delete oTextSave if existing. If System.IO.File.Exists(oTextSave) = True Then System.IO.File.Delete(oTextSave) End If End Sub End Class
Hi Yuvilo;
Thanks again for your help. I was using your rule. I also like to dd more functionality in the rule such as:
I have some of the assemblies of which the BOM structure is phantom. In this case the parent of any child in this assembly is the parent of parent.
Could you shed some light to get around this. is the parent of parent. I have been trying a lot of time without success. I attached a fake-sample.
I request help. Thanks.
Autodesk Inventor 2019
Hi, I have followed your threads about the subject. I've noticed that when it comes to property in phantom, you can use the bill of materials property of the part, you may not have to read it from the property of assembly list model data.
I have found a result but my limitations in programming have not been able to insert it within the rule that you need.
First of all, I think that in order to find father of the father you should use something like this, try it with a large assembly and choose the piece in which your father is phantom, and he will give you back the next father who is not a phantom.
Sub Main() Dim oAsmCompDef As AssemblyComponentDefinition oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition Dim oPart As ComponentOccurrence 'Pick part occurrence oPart = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAssemblyLeafOccurrenceFilter, "Seleccione Pieza") If oPart Is Nothing Then Exit Sub Else Dim partname As String = oPart.Definition.Document.Displayname MessageBox.Show("the origin part is" & partname, "Title") Dim Parent As Document = oPart.Definition.Document.ReferencingDocuments.Item(1) Dim oParentnameA As String = Parent.DisplayName MessageBox.Show("parent component searched " & oParentnameA, "Title")' parent component searched, should not be phantom Dim oBOM As BOM oBOM = ThisApplication.ActiveDocument.ComponentDefinition.BOM Dim oBOMView As BOMView oBOMView = oBOM.BOMViews.Item("Unnamed")'Accesing to Model data Column Call FindParent(oBOMView.BOMRows, 0, oParentnameA ) End If End Sub Sub FindParent(Rows As BOMRowsEnumerator, indent As Integer, oParentnameA As String)' Dim oBOMRow As BOMRow For Each oBOMRow In Rows Dim oDef As ComponentDefinition oDef = oBOMRow.ComponentDefinitions(1) Dim oParentName As String = oDef.Document.Displayname If oParentName <> oParentnameA Then If Not oBOMRow.ChildRows Is Nothing Then Call FindParent(oBOMRow.ChildRows, indent + 1,oParentnameA) End If End If If oParentName = oParentnameA Then Dim oBOMStructnumber As String oBOMStructnumber = oBOMRow.BOMStructure Dim BOM_Structure As String If oBOMStructnumber = 51969 Then BOM_Structure = "The Default Structure Type" If oBOMStructnumber = 51974 Then BOM_Structure = "The inseparable Structure Type" If oBOMStructnumber = 51970 Then BOM_Structure = "The normal Structure Type" If oBOMStructnumber = 51971 Then BOM_Structure = "The phantom Structure Type" If oBOMStructnumber = 51973 Then BOM_Structure = "The purchased Structure Type" If oBOMStructnumber = 51972 Then BOM_Structure = "reference Structure Type" If oBOMStructnumber = 51975 Then BOM_Structure = "The Structure Type varies amongst references" If oBOMStructnumber = 51971 Then Dim oDocFile As Document oDocFile = oDef.Document Dim Parent As Document = oDocFile.ReferencingDocuments.Item(1) oParentnameA=Parent.DisplayName Dim oBOM As BOM oBOM = ThisApplication.ActiveDocument.ComponentDefinition.BOM Dim oBOMView As BOMView oBOMView = oBOM.BOMViews.Item("Unnamed")'Accesing to Model data Column Call FindParent(oBOMView.BOMRows, 0, oParentnameA ) End If If oBOMStructnumber <> 51971 Then MessageBox.Show("the parent is " & oParentnameA & "@" & BOM_Structure, "Title") End If End If Next End Sub
The problem is that once found the value, we should cut the loop, maybe with "exit for" and if instead of a "sub" we use a "function" we could add a "return" and return the value to the sub that we need. I have tried without success, maybe you or maybe the teacher @chandra.shekar.g tell us how to do it if that is the way to the result, or maybe to throw a simpler way.
Regarding the amount I can see, I have not inquired into it yet, regards
Mechanical Designer
