Resolving drawing links with new model states
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
After converting a factory part to a model state part, the drawing links need to be resolved. Is there a best way to do this? I'm able to resolve links within the models themselves but I don't have a lot of experience coding within drawings. Below is close to the code that I use to resolve the assembly links. That I tried to change to work with drawings but doesn't work.
DWG = ThisDoc.PathAndFileName(False) & ".IDW" Dim odraw = ThisApplication.Documents.Open(DWG, True) Dim Path As String Dim Filename As String Dim FilenameBase As String Dim FullFileName As String Dim Resolvedfile As String Dim FilenameWithoutExt As String Dim FilenameWithMS As String For Num = 1 To 9 Dim oFD As FileDescriptor oFD = odraw.ReferencedFileDescriptors(1).DocumentDescriptor.ReferencedFileDescriptor Path = ThisDoc.Path FullFileName = ThisDoc.PathAndFileName(True) ' MessageBox.Show(FullFileName, "FullFileName") FilenameBase = Right$(FullFileName, Len(FullFileName) -InStrRev(FullFileName, "\")) ' MessageBox.Show(FilenameBase, "FileNameBase") Extension = Right(FilenameBase, 4) ' MessageBox.Show(Extension, "Extension") FilenameWithoutExt = Replace(FilenameBase, Extension, "") ' MessageBox.Show(FilenameWithoutExt, "FilenameWithoutExt") Filename = (FilenameWithoutExt & "-0" & Num & Extension) ' MessageBox.Show(Filename, "Filename") FilenameWithMS = FilenameBase & "<" & FilenameWithoutExt & "-0" & Num & ">" ' MessageBox.Show(FilenameWithMS, "FilenameWithMS") Resolvedfile = Path & FilenameWithMS ' MessageBox.Show(Resolvedfile, "Resolvedfile") If oFD.FullFileName = Filename Then oFD.ReplaceReference(Resolvedfile) End If Next odraw.Update
