Hi @gopinathmY575P. You are probably looking for the 'ResolveFile' method. That is a method of the DesignProjectManager, which can be obtained directly from the Inventor Application object (ThisApplication).
ThisApplication.DesignProjectManager.ResolveFile()
If this solved your problem, or answered your question, please click ACCEPT SOLUTION .
Or, if this helped you, please click (LIKE or KUDOS) 👍.
Wesley Crihfield
(Not an Autodesk Employee)
