Dears,
I'm trying convert iLogic Code to VB.NET as this post:
https://forums.autodesk.com/t5/inventor-ilogic-and-vb-net-forum/derived-part-replace-model-reference...
https://forums.autodesk.com/autodesk/attachments/autodesk/78/469742/1/BasePartReplacer.iLogicVb.txt
And my working code:
Private Sub TestingButton_OnExecute(Context As NameValueMap) Handles TestingButton.OnExecute
TopDOC = _InventorApp.Document
Replace()
End Sub
Private TopDOC As Document
Public Sub Replace()
If (Not _InventorApp.ComponentDefinition.RepresentationsManager.LevelofDetailRepresentations("Master").Activate()) Then Return
Dim DOCtoReplace As Document = FindDocToReplace()
If (DOCtoReplace Is Nothing) Then Return
Dim ReplacementFileName As String = SelectReplacementFilename(DOCtoReplace.DisplayName)
If (String.IsNullOrEmpty(ReplacementFileName)) Then Return
If (String.Equals(DOCtoReplace.FullFileName, ReplacementFileName, StringComparison.OrdinalIgnoreCase)) Then Return
Dim ReplacementPart As Document = _InventorApp.Documents.Open(ReplacementFileName, False)
Dim DoReplace As Boolean = True
If (ReplacementPart.InternalName <> DOCtoReplace.InternalName) Then
MessageBox.Show("THE REPLACEMENT PART (" & ReplacementPart.DisplayName & ") CANNOT BE USED.", "BASE PART REPLACER", MessageBoxButtons.OK, MessageBoxIcon.Warning)
DoReplace = False
End If
ReplacementPart.ReleaseReference()
If (Not DoReplace) Then Return
Dim FilenameToReplace As String = DOCtoReplace.FullFileName
ReplaceReferences(TopDOC, FilenameToReplace, ReplacementFileName)
TopDOC.Update()
End Sub
Function FindDocToReplace() As Document
Dim BasePartList As New List(Of Document)
If (TopDOC.DocumentType = DocumentTypeEnum.kPartDocumentObject) Then
AddBaseParts(BasePartList, TopDOC)
Else
For Each RefDoc As Inventor.Document In TopDOC.AllReferencedDocuments
If (RefDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject) Then
AddBaseParts(BasePartList, RefDoc)
End If
Next
End If
If (BasePartList.Count = 0) Then
MessageBox.Show("NO BASE PARTS WERE FOUND IN THE DOCUMENT: " & TopDOC.DisplayName, "BASE PART REPLACER")
ElseIf (BasePartList.Count = 1) Then
Return BasePartList(0)
Else
Dim PartNameList As New List(Of String)
For Each baseDoc As Document In BasePartList
PartNameList.Add(baseDoc.DisplayName)
Next
'Dim SelectedName As String = InputListBox("SELECT THE PART TO REPLACE", PartNameList, PartNameList(0), "REPLACE PART", "PARTS").ToString()
Dim selectedName As String = InputBox("SELECT THE PART TO REPLACE", "PartNameList", "PartNameList(0)", , )
Dim SelectedIndex As Integer = PartNameList.IndexOf(SelectedName)
Return BasePartList(SelectedIndex)
End If
Return Nothing
End Function
Sub AddBaseParts(ByVal BasePartList As List(Of Document), ByVal DOC As Document)
For Each RefDoc As Document In DOC.ReferencedDocuments
If (RefDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject AndAlso Not IsiPartMember(RefDoc)) Then
If (Not BasePartList.Contains(RefDoc)) Then
BasePartList.Add(RefDoc)
End If
End If
Next
End Sub
Function IsiPartMember(ByVal DOC As Document) As Boolean
If (DOC.DocumentType <> DocumentTypeEnum.kPartDocumentObject) Then Return False
Dim PartDoc As PartDocument = DirectCast(DOC, PartDocument)
Return PartDoc.ComponentDefinition.IsiPartMember
End Function
Function SelectReplacementFilename(ByVal FilenameToReplace As String) As String
Dim oFileDlg As Inventor.FileDialog = Nothing
_InventorApp.CreateFileDialog(oFileDlg)
oFileDlg.Filter = "Part Files (*.ipt)|*.ipt"
oFileDlg.DialogTitle = "Replace " & FilenameToReplace
oFileDlg.InitialDirectory = _InventorApp.Path
oFileDlg.CancelError = False
Try
oFileDlg.ShowOpen()
Return oFileDlg.FileName
Catch
End Try
Return String.Empty
End Function
Sub ReplaceReferences(ByVal DOC As Document, ByVal FilenameToReplace As String, ByVal ReplacementFileName As String)
ReplaceReferencesInOneDoc(DOC, FilenameToReplace, ReplacementFileName)
For Each SubDoc As Document In DOC.AllReferencedDocuments
If (String.Equals(SubDoc.FullFileName, FilenameToReplace, StringComparison.OrdinalIgnoreCase) OrElse String.Equals(SubDoc.FullFileName, ReplacementFileName, StringComparison.OrdinalIgnoreCase)) Then
Continue For
End If
ReplaceReferencesInOneDoc(SubDoc, FilenameToReplace, ReplacementFileName)
Next
End Sub
Could you please help me correct my code. Thanks!
Hi @ngnam1988
Your missing the sub routine "ReplaceReferencesInOneDoc". So your calling a sub routine that does not exist. This is why the error message statement "ReplaceReferencesInOneDoc is not declared is shown. So you need to either delete that sub routine call or create the sub routine.
Sub ReplaceReferencesInOneDoc(DOC, FilenameToReplace, ReplacementFileName)
'Need some code.
End SUb
Thanks @A.Acheson ,
I just add them to working code, but it can't run in correct way - with out error report. Could you please help me? Thanks,
Replace()
End Sub
Public TopDOC As Document
If (Not LevelOfDetailIsMaster()) Then Return
DoReplace = False
End If
TopDOC.Update()
End Sub
Else
End If
Next
End If
Else
Next
'Dim selectedName As String = InputBox("SELECT THE PART TO REPLACE", "PartNameList", "PartNameList(0)", , )
End If
Return Nothing
End Function
End If
End If
Next
End Sub
End Function
Try
oFileDlg.ShowOpen()
Catch
End Try
Return String.Empty
End Function
Continue For
End If
Next
End Sub
Sub ReplaceReferencesInOneDoc(ByVal doc As Document, ByVal fileNameToReplace As String, ByVal replacementFileName As String)
For Each docDesc As DocumentDescriptor In doc.ReferencedDocumentDescriptors
Dim desc As FileDescriptor = docDesc.ReferencedFileDescriptor
If (desc.ReferenceMissing) Then Continue For
Console.WriteLine("Referenced RelativeFileName = " & desc.RelativeFileName)
Trace.WriteLine("Referenced RelativeFileName = " & desc.RelativeFileName)
If (String.Equals(desc.FullFileName, fileNameToReplace, StringComparison.OrdinalIgnoreCase)) Then
desc.ReplaceReference(replacementFileName)
Exit For
End If
Next
End Sub
Function LevelOfDetailIsMaster() As Boolean
Dim assemDoc As AssemblyDocument = TryCast(TopDOC, AssemblyDocument)
If (assemDoc Is Nothing) Then Return True
Dim repMgr As RepresentationsManager = assemDoc.ComponentDefinition.RepresentationsManager
Dim lodType As LevelOfDetailEnum = repMgr.ActiveLevelOfDetailRepresentation.LevelOfDetail
If (lodType <> LevelOfDetailEnum.kMasterLevelOfDetail) Then
MessageBox.Show("This rule can only be run in the Master Level of Detail.", "Base Part Replacer")
Return False
End If
Return True
End Function
Hi @ngnam1988
From the code supplied you are missing some key ingredients.
Imports Inventor
Imports System.Runtime.InteropServices
Dim _InventorApp As Inventor.Application = Marshal.GetActiveObject("Inventor.Application")
Dim TopDOC As Document = _InventorApp.ActiveDocument
See this video for setting up and accessing Inventor Application.
https://www.youtube.com/watch?v=NrNXxYCwAfc
Here is the error list I received from the code provided. Inputlist box is not allowed in Visual studio so you will either need to create your own dialog or alternatively just comment during testing.
Are you trying to create an application or will this be run as an external rule in inventor? I do not have visual studio and inventor together so I cannot test the entire code. Maybe other forum users can assist here.
