Hello Everybody,
in Inventor you can replace an occurrence by another part of different origin. Usually, the constraints will break, as Inventor cannot find the corresponding geometry at the new part:
You can then repair that constraint in the GUI by telling Inventor which geometry it shall take on the new part instead by picking it in the graphics window:
So far so good.
Now i would like to repair my constraint via API. Apparently this seems not possible, as the entityX-property of my constraint is read only:
Do I really have to recreate that constraint completely and delete the old one?
This is quite unsatisfactory!
Solved by Bert_Bimmel. Go to Solution.
I offer you another way, why don't you use the main planes, main axes to make the restriction? For example, if you have a part file and its constraints are referenced with the main plans, when replacing it with another part file the constraints will not fail. When it comes to faces of solid bodies, these will always fail because each face will be identified with a unique name. The new problem you will have in this way is that your constraints will fail if you replace a part with a subassembly. But I have another solution, place 3 constraints between main planes for part and 3 constraints between main planes for assembly, depending on what type of file it is (part or assembly) you will activate and deactivate the constraints you need.
Another way is through imates. I tried it once but at that time it gave me problems in specific situations so I followed the way that I have detailed.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
I don't see it as cumbersome, in the case of a screw, there are only 2 constraints. Workplane with face and axis with axis. In any case, I hope you find a simple solution, many times it is about simplifying and avoiding paths that lead to errors in automation. Big hug colleague!
Mechanical Designer
Ok, and now I do not exchange the screw, but the plate with the hole instead, and inventor does'nt find the corresponding hole again?
But I found the answer to my question myself:
Just convert your MateConstraint to a MateConstraint...
... and you can redefine the geometry to use completely without having to delete and recreate it
Who's supposed to come up with this workflow?
