Remove parameter from User Parameters after adding to Custom Parameter Group
DRoam
Mentor Mentor
Message 1 of 11
DRoam
I've just learned how to create a custom parameter group and add a parameter to it. However, the parameter remains in the User Parameters group. Is it possible to remove it from there so it's only shown in my custom group?
Replies (10)
Message 2 of 11
Pratik.Ksoni
You can right click on User parameter and delete it.
See attached file can help you.
Pratik
Message 3 of 11
CCarreiras
@Pratik.Ksoni, i think DRoam is trying to do that with programing code.
I believe a mentor (rank10) of this forum knows how to delete a parameter...
CCarreiras
Message 4 of 11
DRoam
Deleting the parameter deletes the parameter entirely (including from my custom group). I don't want to delete it, I just want to remove it from the User Parameters group so it's only shown in my custom group.
Example:
Message 5 of 11
JaneFan
Hey @DRoam
There is no options when adding parameters into custom group to do so in API, so that the parameter need reside in both the original folder and the custom parameter folder now.
Jane Fan
Inventor/Fusion QA Engineer
Message 6 of 11
dgreatice
Note: You cant delete/remove original parameter.
Try this:
Dim oApp As Application
Dim oPD As PartDocument
Dim oPCD As PartComponentDefinition
Dim oPs As Parameters
Dim oUps As UserParameters
Dim oUP As UserParameter
Dim MyGroupParam As CustomParameterGroup
Dim MyParamList As New ArrayList
oApp = ThisApplication
oPD = oApp.ActiveDocument
oPCD = oPD.ComponentDefinition
oPs = oPCD.Parameters
oUps = oPs.UserParameters
InputField:
MyGroups = InputBox("Enter Name of Groups", "Enter Field")
Try
	MyGroupParam = oPs.CustomParameterGroups.Add(MyGroups, MyGroups)
	GoTo AddParameters
Catch
	MsgBox("Group Parameter Already Exist, Please Create Another Name", msgboxstyle.Critical, "Error")
	GoTo InputField
End Try
AddParameters :
For Each oUP In oUps
	MyParamList.Add(oUP.Name)
Next
MySelectedParam = InputListBox("Select Parameters", MyParamList)
	If oUP.name = MySelectedParam Then
		MyGroupParam.Add(oUP)
Next
Please use the ACCEPT AS SOLUTION or KUDOS button if my Idea helped you to solve the problem.
Autodesk Inventor Professional Certified 2014
Message 7 of 11
DRoam
@JaneFan thank you for confirming for me.
For anyone who would like to vote, I created a request for this here: API: Put parameter in custom parameter group only (remove from User Parameters).
Message 8 of 11
There must have been a way of doing this in the past.
Message 9 of 11
Oops, just realized, how I accomplished this before. It was not custom parameters, but object parameters.
Sorry
/Michael
Message 10 of 11
hamed_nemati
How can you create custom paremeters group?
Message 11 of 11
WCrihfield
