Regarding Font Size in Drawing Sheet
- Mute
- Permalink
- Report
I have two methods name AddDrawingView and Dimensions.
I am calling the Dimensions in this method AddDrawingView
like
private void AddDrawingView_Fascade(DrawingDocument drawingDoc, AssemblyDocument asmDoc)
////MYCODE////
Dimensions()
In AddDrawingView method I have used the code to arrange the name of the views like FRONT and TOP with a font size of around 0.55 according to the code below
view.Name = view_name;
Point2d position = inventor_app.TransientGeometry.CreatePoint2d(x_offset, y_offset);
GeneralNote text_1 = drawingSheet.DrawingNotes.GeneralNotes.AddFitted(position, view_name);
text_1.FormattedText = view_name;
text_1.TextStyle.FontSize = 0.55;
and in Dimensions method I am giving font size to numeric value i.e. dimensions by using this code
foreach (GeneralDimension dimension in drawingDoc.ActiveSheet.DrawingDimensions.GeneralDimensions)
if (dimension.Type == ObjectTypeEnum.kLinearGeneralDimensionObject)
if (Empty)
//MYCODE///
else
dimension.Style.TextStyle.FontSize = 0.12
dimension.Precision = 1;
dimension.Style.TextStyle.Bold = true;
But when my AddDrawingView methods gets runs it makes the view name of proper size i.e. 0.55 but after making this when the second method is called i.e. Dimensions its makes all the values i.e the dimesnion which are numeric and the view name which is Text to font size of 0.12
I want the text font size i.e. view_name should have 0.55 font size and the dimension value which are numeric should be 0.12 in my drawing sheet]
I don't know what the issue is
Can anyone help me to solve this
Thank you in Advance
