Hi, i'm trying to reference the same part file multiple times using a "for each" loop. this is my code
Dim oADoc As AssemblyDocument = ThisDoc.Document Dim oADef As AssemblyComponentDefinition = oADoc.ComponentDefinition Dim oOccName As String = "ExCross" Dim oOcc As ComponentOccurrence = oADoc.ComponentDefinition.Occurrences.ItemByName(oOccName)
For Each oOccPart As ComponentOccurrence In oOcc.OccurrencePath ' Dim refDoc As PartDocument = oOcc.Definition.Document If InsDepthBuild >= 21 Then CrossDepthBuild = 12 CF = CrossDepthBuild oOcc.Visible = True ' Component.Visible("ExCross") = True ' Component.Visible("ExCross:1") = True Else If InsDepthBuild <= 21 Then CrossDepthBuild = InsDepthBuild CF = CrossDepthBuild oOcc.Visible = False End If Next
i want oOcc to reference all occurences of my part called "ExCross" instead of having to write in every instance of said file (i.e. ExCross:1, ExCross:2....) since this specific part is driven by a pattern, i thought it would be easier to just reference the actual part file, then have it count every instance of said part(no matter the trailing instance number) then have it turn invisible if set value is lower than 21, and have it turn visible again if set value is higher than 21.
am i approaching this wrong, or am i forgetting something? as the code is right now it will only show/hide one instance of the part instead of all of them.
Solved by op_thorsager. Go to Solution.
Solved by WCrihfield. Go to Solution.
Hi @op_thorsager. There are a couple/few ways of doing what I think you are trying to do. One way is to loop through all components, while checking if the Name of the component 'StartsWith' the name you are specifying. Below is a quick example of that route.
Dim oOccs As ComponentOccurrences = oADef.Occurrences
For Each oOcc As ComponentOccurrence In oOccs
If oOcc.Name.StartsWith("ExCross") Then
'do something with oOcc object here
End If
Next
Another way to get all of the components that reference a specific document is to use the following lines of code...keeping in mind how I am defining the 'oOccs' variable above.
Dim oPDoc As Document = ThisApplication.Documents.ItemByName("PartFullDocumentName")
Dim oAllPartRefOccs = oOccs.AllReferencedOccurrences(oPDoc)
However, I am not sure about the other variables you are using in your code, such as 'CrossDepthBuild' & 'InsDepthBuild'. If those are 'local' parameters of the main assembly, that might be OK, but if those are supposed to be representing parameter values in the referenced part, that would be a problem. If they do not represent local parameters, then I do not know where their Types or Values have been set.
Wesley Crihfield
(Not an Autodesk Employee)
End If
Next
Wesley Crihfield
Thank you! will have to check the code tomorrow, but since it you i'm almost 100% certain it works as i want it to. the InsDepth build and the other variables are local parameters in the main assembly, which changes other parameters within some parts related to the for each loop. they work as intended, and so far i've had no issues with them 🙂
everything works as expected, after tweaking when the code you posted does specific things, to ensure that the parameters which was in the original code would work with the for each. the one you sent would delete all component occurences of the entire assembly for some reason (im guessing it was due to the parameters) i patched it up and got it working as intended with the following code:
If InsDepthBuild >= 22 Then
oOcc.Visible = True
End If
'adjusts depth of visible/invisible component to flush with insdepthbuild
ExCrossDepth = InsDepthBuild - CrossDepthBuild
end if
End If
Next
oOcc.Visible = True
End If
end if
End If
Next
