Referenced File Descriptors
I saw a reference that Mike Martin made to SilentMode when changing the path
of referenced files. Anyone know what he is talking about?
I am trying to copy a set of files to a new location and want to "break the
link to the old location and supply a new path. Anyone got an example?
Tim Strandberg
Could you mean SilentOperation?
Gets/sets the Boolean flag that controls whether an operation will proceed without
prompting (if that gets required...e.g.: error message dismissal). If Autodesk Inventor is
running visible, this property is FALSE by default.
Kent
Assistant Moderator
Autodesk Discussion Forum Moderator Program
"Tim Strandberg" wrote in message
news:F5D190C661F9BDA3C80B96E92ABFB6ED@in.WebX.maYIadrTaRb...
> Thanks
> Tim Strandberg
Well that makes more sense. But my other question still stands. Has anyone
done anything, preferably from Apprentice regarding reference paths?
Thanks Kent!
"Kent Keller" wrote in message
news:20408BA58F40A1DAB120D7D976EFF63B@in.WebX.maYIadrTaRb...
without
> Kent
> Assistant Moderator
path
the
> > Thanks
> > Tim Strandberg
the
I have done a similar job - "copy a assembly file". I traversed the copied
assembly file and call for all component occurrence's the methode Replace
with the new file location path, to break the link to the old location.
Alexander
Tim
This resopnse is dated, so I bet you have a solution by now, but her goes.
If I understand you right. You are trying to programatically change the path of referenced files of an assembly.
There is a sample code fiund in the inventor help under apprentice. Here it is. (hope it pastes in ok)
Private Sub ChangeReferenceSample()
Dim oApprentice As New ApprenticeServerComponent
' Open a document.
Dim oDoc As ApprenticeServerDocument
Set oDoc = oApprentice.Open("C:\Temp\Assembly1.iam")
' Iterate through the references looking for a
' reference to a specific file.
Dim oRefFileDesc As ReferencedFileDescriptor
For Each oRefFileDesc In oDoc.ReferencedFileDescriptors
If oRefFileDesc.FullFileName "C:\Temp\OldPart.ipt" Then
' Replace the reference.
Call oRefFileDesc.PutLogicalFileNameUsingFull( _
"C:\Temp\NewPart.ipt")
Exit For
Next
' Set a reference to the FileSaveAs object.
Dim oFileSaveAs As FileSaveAs
Set oFileSaveAs = oApprentice.FileSaveAs
' Save the assembly.
Call oFileSaveAs.AddFileToSave(oDoc, oDoc.FullFileName)
Call oFileSaveAs.ExecuteSave
End Sub
I have to get out here more often, I know this is a month past due.
JP
Darn,I knew that would happen.
' Open a document.
If oRefFileDesc.FullFileName = "C:\Temp\OldPart.ipt" Then
Exit For
Next
End Sub
OK - But what if the destination is another
folder???
/ Michael Christoffersen
