Properties Add In to Change Label Names
Message 1 of 8
We are looking to create an add-in to rename the labels of the properties object.
When you right click on properties these are the tabs
General Summary Project Status Custom Save Physical
Under Summary
Title
Replies (7)
Message 2 of 8
Look at the posts in IV7 news group named:
Survey: iProps Wizard Question
and
iProp Wizard Usage Suggestions
Perhaps this will help you when I'm done with it. You cannot change the
Inventor properties dialogue. But you can use a replacement
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
www.sdotson.com/faq.html
"jat14" wrote in message news:f171644.-1@WebX.maYIadrTaRb...
object.
> Under Summary
> Title
Message 3 of 8
Sean
Can you tell me the dates of the posts?
Janice
Message 4 of 8
Here are weblinks to the versions of the article..
http://tinyurl.com/fbh3
http://tinyurl.com/fbhb
Sean Dotson, PE
"jat14" wrote in message news:f171644.1@WebX.maYIadrTaRb...
> Sean
> Janice
Message 5 of 8
Is it possible to get some sample code of how we can change label properties (example company in the summary tab of properties)
Janice
Message 6 of 8
You would have to create your own form. I don't think there is any way to change the
existing labels in the iProperties dialog. I think there might be a example of something
similar in the SDK folder.
Kent
Assistant Moderator
Autodesk Discussion Forum Moderator Program
"jat14" wrote in message news:f171644.3@WebX.maYIadrTaRb...
> Janice
Message 7 of 8
I am very new to API in Inventor
I am not new to programming or VBA
Can you tell me if I am thinking correctly
of how to put in different properties
1. Create a addin .dll with a form with properties that i want
2. Create a new propertyset with new properties(this is in the sdk)
The addin .dll will show the form with the new properties
How do i get the new form to override the current properties form?
How come in the sdk they use apprentice server instead of inventor
i see the new form in the sdk and i see the new propertyset and the new properties How do you get the new form to be the one that pops up when they click the properties menu item
Help Please???
Janice
Message 8 of 8
I don't know if it is possible or not to override the current properties form. I am
guessing not, but could easily be wrong.
Apprentice server is a smaller light weight subset of the Inventor API. You can use it
in anything from Excel and Word to VB. If all you are doing is properties then it is
probably the best way to go. I don't know what example your are talking about in the sdk,
but if it is a addin.dll I don't know why they would use apprentice since the dll has to
run in process inside Inventor. I am thinking it is probably a EXE?
I think the best you could do (at least to my knowledge) is to add a toolbutton or some
way to bring up your properties dialog rather than the built in one.
I am kind of curious why you need more than what Custom Properties offer?
Kent
Assistant Moderator
"jat14" wrote in message news:f171644.5@WebX.maYIadrTaRb...
> Help Please???
> Janice
