Recursive External Rule
2 REPLIES 2
meGVGMF
293 Views, 2 Replies
Hi
I'm trying to simplify my life by using recursion with `iLogicVb.Automation.RunExternalRule()`, where the external rule calls itself with a different context document argument.
From what I can tell, this isn't possible. I don't get any errors or crashes. It just runs through one level and ends.
Is it not possible to call rules recursively?
2 REPLIES 2
WCrihfield
in reply to: meGVGMF
Good question.  I don't think I have ever tried a 'true' recursive external rule which runs itself again at certain points, in a traditional sense.  However, it does not make sense to me that it would work, because the rule would already be running in Inventor's memory, while it is being called to run again.  I have certainly used recursive Sub routines before many times, and have use tricks like 'GoTo RunAgain' at the end of a process, if certain conditions are right, though.
What sort of process are you trying to automate this way?
Wesley Crihfield
(Not an Autodesk Employee)
meGVGMF
in reply to: WCrihfield
Thanks for the response.
It could be that it's restricted arbitrarily, to avoid having to deal with the ramifications elsewhere.
But, anyway, like you mention, immediately after posting this and figuring there was no way to push through, I reframed the problem and, instead of putting the rule in the recursion, put the recursion in the rule. It's maybe a little more legible, but instead of recursing to the bottom and building up (addressing parts before their respective assemblies) I put every document gathered into an array and iterate backwards through it.
