In the Add function documentation there are two parameters XDirectionStartPoint and YDirectionStartPoint.
But are these 3d or 2d points? Maybe 2d points on a sketch.
And if there was a c++ example of use it would be great!
Solved by philippe.leefsma. Go to Solution.
Hi Oransen,
Those parameters accept SketchPoint3D, so you need to create or use an existing Sketch3D.
Unfortunately I don't have a C++ sample ready to provide you but let us know if you have further issues with that topic.
Philippe.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution"
button. This helps everyone find answers more quickly!
Thanks for the extra info.
I've managed to get Add working by passing an empty ComVariant in the 7th and 13th parameters.
