Read Excel sheet into iProperties, then populate BOM
- Mute
- Permalink
- Report
Long story shorter, I am not an Inventor user. This is done per the request of a co-worker who uses Inventor (2019). He wants to me write some code to compare an iProperty "Stock Number" to an excel sheet, with a column A "Purchased Item". These two (Part Number and Purchased Item) contain the exact same information. What I need to do is compare both of these values, and if they match, pull from Column B "Internal Part Number" and import it into inventor as a new custom column in the BOM.
What I have so far as far as code, is to pull the values from the Excel sheet, and import them as a new iProperty, but for some reason, it only populates the iProperty for the overall Assembly, not the Part files. I need it to iterate through all the part files, and compare the two values and then pull from the excel sheet for only those that match. From my limited knowledge of how this software works, I assume the BOM pulls data from each individual part, so I figured if I updated the iProperties of the parts, I could go from there and pull them into the BOM. That would be the second question Ill ask later.
Is there an easy way to iterate through the part files and then compare them using some of the code I wrote below? Or is it something else entirely.
Dim oProj As String Dim oSheet As String oProj = iProperties.Value("Project", "Stock Number") GoExcel.Open("C:\Users\PATHHERE","EXCELSHEETNAME") For rowPR = 2 To 2000 If (GoExcel.CellValue("A" & rowPR) = oProj) Then oSheet = GoExcel.CellValue("B" & rowPR) iProperties.Value("Custom", "Internal Part Number") = oSheet Exit For End If Next GoExcel.Close
