Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
RangeBox for a Sketch
5 REPLIES 5
J.Pelfrene
412 Views, 5 Replies
Is there a method for getting the RangeBox of a Sketch in a PartDocument?
Sketch, Profile, RegionProperties, SketchBlock, ... None of these offer a RangeBox method. SketchEntity does, but that's for a single entity, not the entire sketch.
Thanks!
5 REPLIES 5
JelteDeJong
in reply to: J.Pelfrene
You can make your own function. something like this:
Dim doc As PartDocument = ThisDoc.Document
Dim sketch As PlanarSketch = doc.ComponentDefinition.Sketches.Item(1)
Dim allMinPoints As List(Of Point2d) = sketch.
	SketchEntities.
	Cast(Of SketchEntity).
	Select(Function(e) e.RangeBox.MinPoint).
	OrderBy(Function(p) p.X).ToList()
Dim minX = allMinPoints.First().X
Dim minY = allMinPoints.OrderBy(Function(p) p.Y).First().Y
Dim allMaxPoints As List(Of Point2d) = sketch.
	SketchEntities.
	Select(Function(e) e.RangeBox.MaxPoint).
Dim maxX = allMaxPoints.Last().X
Dim maxY = allMaxPoints.OrderBy(Function(p) p.Y).Last().Y
Dim rangebox As Box2d = ThisApplication.TransientGeometry.CreateBox2d()
rangebox.MinPoint = ThisApplication.TransientGeometry.CreatePoint2d(minX, minY)
rangebox.MaxPoint = ThisApplication.TransientGeometry.CreatePoint2d(maxX, maxY)
sketch.Edit()
sketch.SketchLines.AddAsTwoPointRectangle(rangebox.MinPoint, rangebox.MaxPoint)
 Edit: I found a bug after posting and i solved it.
Jelte de Jong
Blog: hjalte.nl - github.com
J.Pelfrene
in reply to: JelteDeJong
Thank you!
I thought of doing it this way too, but was afraid it would be computationally expensive. It is not!
And interesting to learn something from your code as well.
Cheers
j_weber
@JelteDeJong
Great code.
Is it also possible to change the color of the range box to for example orange or to change the style to construction
Jörg Weber
CAD Systemtechniker für AutoCAD, Inventor, Vault
JelteDeJong
in reply to: j_weber
you can try it like this:
	SketchEntities.
	SketchEntities.
sketch.Edit()
Dim lines = sketch.SketchLines.AddAsTwoPointRectangle(rangebox.MinPoint, rangebox.MaxPoint)
Dim red = ThisApplication.TransientObjects.CreateColor(255, 0, 0)
For Each line As SketchLine In lines
	line.Construction = True
	line.OverrideColor = red
Next
Jelte de Jong
j_weber
Thanks a lot 🙂
Jörg Weber
