Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
"Illegal characters in path" help
3 REPLIES 3
claudio.ibarra
2326 Views, 3 Replies
claudio.ibarra
Note: I couldn't attach the iLogic rule as .iLogicVb, so I renamed it to .txt. I don't know if that breaks it when sharing.
What I believe the code is supposed to do / what I want it to do:
  • Go through each item in the Model browser (subassemblies included)
  • Check if there is a drawing that match's the item's name in the same folder as the item.
  • If yes, make a PDF.
  • Go to next item.
I'm getting an error about illegal characters in path. I imagine that's something like a comma in the assembly? Is there a simple thing I can add to this code to make it skip past anything that would generate an error?
The text of the rule itself is here:
Option Explicit On
Imports System.io
Imports System.LINQ
Sub Main
Dim extensions As String() = {".dwg", ".idw"}
    Dim defaultDrawingExtension = ".idw" ' ".dwg"
    Dim dir As DirectoryInfo = Nothing
    Dim JustDoIt As Boolean = True
    Dim newPDFName As String = ""
    Dim trimmedfilename As String = ""
    Dim drawingfiles As List(Of FileInfo) = Nothing
    'check that the active document is an assembly file
    If ThisApplication.ActiveDocument.DocumentType <> DocumentTypeEnum.kAssemblyDocumentObject Then
        MessageBox.Show("Please run this rule from the assembly file.", "iLogic")
        Exit Sub
    End If
    'define the active document as an assembly file
    Dim oAsmDoc As AssemblyDocument
    oAsmDoc = ThisApplication.ActiveDocument
    Dim oAsmName As String = System.IO.Path.GetFileNameWithoutExtension(oAsmDoc.FullFileName) 'Left(oAsmDoc.DisplayName, Len(oAsmDoc.DisplayName) -4)
    'MessageBox.Show(oAsmName)
    'get user input
    Dim RUsure As DialogResult = MessageBox.Show(
    "This will create a PDF file for all of the assembly components that have drawing files." _
    & vbLf & "This rule expects that the drawing file shares the same name and location as the component." _
    & vbLf & " " _
    & vbLf & "Are you sure you want to create PDF Drawings for all of the assembly components?" _
    & vbLf & "This could take a while.", "iLogic  - Batch Output PDFs ", MessageBoxButtons.YesNo)
    If RUsure = vbNo Then
        Exit Sub
    End If
    'MessageBox.Show("Continuing")
    '- - - - - - - - - - - - -PDF setup - - - - - - - - - - - -
    Dim oPath As String = ThisDoc.Path
    Dim PDFAddIn As TranslatorAddIn = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
    Dim oContext As TranslationContext = ThisApplication.TransientObjects.CreateTranslationContext
    oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
    Dim oOptions As NameValueMap = ThisApplication.TransientObjects.CreateNameValueMap
    Dim oDataMedium As DataMedium = ThisApplication.TransientObjects.CreateDataMedium
    If PDFAddIn.HasSaveCopyAsOptions(oAsmDoc, oContext, oOptions) Then
        oOptions.Value("All_Color_AS_Black") = 0
        'oOptions.Value("Remove_Line_Weights") = 0
        'oOptions.Value("Vector_Resolution") = 400
        oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets
        'oOptions.Value("Custom_Begin_Sheet") = 2
        'oOptions.Value("Custom_End_Sheet") = 4
    End If
    'get PDF target folder path
    Dim oFolder As String = System.IO.Path.GetDirectoryName(oAsmDoc.FullFileName) & "\" & oAsmName & " PDF Files"
    MessageBox.Show("Looking for: " & oFolder & " & Creating it if it doesn't already exist!")
    'Check for the PDF folder and create it if it does not exist
    If Not System.IO.Directory.Exists(oFolder) Then
        System.IO.Directory.CreateDirectory(oFolder)
    End If
    '- - - - - - - - - - - - -Component Drawings - - - - - - - - - - - -
    'look at the files referenced by the assembly
    Dim oRefDocs As DocumentsEnumerator
    oRefDocs = oAsmDoc.AllReferencedDocuments
    Dim oRefDoc As Document
    For Each oRefDoc In oRefDocs
        Dim filename As String = oRefDoc.FullDocumentName
        Dim ThisFileDir As String = System.IO.Path.GetDirectoryName(oRefDoc.FullDocumentName)
        If Not JustDoIt Then
            RUsure = MessageBox.Show(filename, "PDF This file?", MessageBoxButtons.YesNo)
                Continue For
            End If
        End If
        dir = New DirectoryInfo(ThisFileDir)
        trimmedfilename = System.IO.Path.GetFileNameWithoutExtension(filename)
        drawingfiles = GetFilesByExtensions(dir, trimmedfilename, extensions)
        If drawingfiles.Count = 1 Then
            Dim oDrawDoc As DrawingDocument
            oDrawDoc = ThisApplication.Documents.Open(drawingfiles.Item(0).FullName, True)
            Dim oFileName As String = System.IO.Path.GetFileNameWithoutExtension(oRefDoc.DisplayName)
			Dim tempRev As String = GetRevisionProp(oDrawDoc)
            newPDFName = oFolder & "\" & oFileName & " R" & tempRev &  ".pdf"
            If System.IO.File.Exists(newPDFName) Then
                If CheckReadOnly(newPDFName) Then
                    MessageBox.Show("PDF Exists and is read only," & vbCrLf & "Suggest you close it or check it out of Vault!" & vbCrLf & "before trying this rule again!")
                    Exit Sub
                End If
            End If
            oDataMedium.FileName = newPDFName
            Call PDFAddIn.SaveCopyAs(oDrawDoc, oContext, oOptions, oDataMedium)
            oDrawDoc.Close()
        ElseIf drawingfiles.Count > 1 Then
            MessageBox.Show("We found multiple format drawing files!" & vbCrLf & "Please correct this before trying again!")
        ElseIf drawingfiles.Count = 0 Then
            ThisApplication.StatusBarText = "No Matching drawing file found for: " & filename
        End If
    Next
    '- - - - - - - - - - - - -Top Level Drawing - - - - - - - - - - - -
    Dim assyfilename As String = oAsmDoc.FullFileName
    Dim assyFileDir As String = System.IO.Path.GetDirectoryName(oAsmDoc.FullFileName)
    dir = New DirectoryInfo(assyFileDir)
    trimmedfilename = System.IO.Path.GetFileNameWithoutExtension(assyfilename)
        Dim oAsmDrawingDoc As DrawingDocument = ThisApplication.Documents.Open(drawingfiles.Item(0).FullName, True)
        Dim oAsmDrawingName As String = System.IO.Path.GetFileNameWithoutExtension(oAsmDrawingDoc.FullFileName)
		Dim tempRev = GetRevisionProp(oAsmDrawingDoc)
        newPDFName = oFolder & "\" & oAsmDrawingName & " R" & tempRev &  ".pdf"
                Exit Sub
            Else
                Call PDFAddIn.SaveCopyAs(oAsmDrawingDoc, oContext, oOptions, oDataMedium)
            End If
        Else
        End If
        'Close the top level drawing
        oAsmDrawingDoc.Close()
    End If
    'MessageBox.Show("New Files Created in: " & vbLf & oFolder, "iLogic")
    'open the folder where the new ffiles are saved
    Shell("explorer.exe " & oFolder, vbNormalFocus)
End Sub
Public Function GetFilesByExtensions(dir As DirectoryInfo, filename As String, ParamArray extensions As String()) As List(Of FileInfo)
    If extensions Is Nothing Then
        Throw New ArgumentNullException("extensions")
    End If
    Dim files = dir.EnumerateFiles("*.*", SearchOption.AllDirectories).Where(Function(s As FileInfo) Not (s.FullName.Contains("OldVersions")) And (System.IO.Path.GetFileNameWithoutExtension(s.FullName).ToLower() = filename.ToLower()))
    'Dim files = dir.EnumerateFiles("*.*", SearchOption.AllDirectories).Where(Function(s As FileInfo) Not (s.FullName.Contains("-")) And Not (s.FullName.contains("OldVersions")))
    Return files.Where(Function(f As FileInfo) extensions.Contains(f.Extension)).OrderBy(Function(x As FileInfo) x.Name).ToList()
End Function
Public Shared Function CheckReadOnly(ByVal doc As String) As Boolean
    Try
        ' Handle the case with the active document never saved
        If System.IO.File.Exists(doc) = False Then
            MessageBox.Show("Save file before executing this method. Exiting ...")
            Return False
        End If
        Dim atts As System.IO.FileAttributes = IO.File.GetAttributes(doc)
        If ((atts And System.IO.FileAttributes.ReadOnly) = System.IO.FileAttributes.ReadOnly) Then
            Return True
        Else
            'The file is Read/Write
            Return False
        End If
    Catch ex As Exception
        MessageBox.Show(ex.Message)
        Return False
    End Try
End Function
Public Shared Function GetRevisionProp(ByRef MyDocument As Document) As String
	Dim oPropSets As PropertySets
	Dim oPropSet As PropertySet
	Dim oRevNumiProp As [Property]
	' Get the PropertySets object.
    oPropSets = MyDocument.PropertySets
	' Get the design tracking property set.
    oPropSet = oPropSets.Item("Inventor Summary Information")
	' Get the part number iProperty.
    oRevNumiProp = oPropSet.Item("Revision Number")
	If oRevNumiProp.Value <> "" Then
		GetRevisionProp = oRevNumiProp.Value
	Else
		GetRevisionProp = "A"
	End If
End Function
  • Go to next item.
Option Explicit On
Imports System.io
Imports System.LINQ
Sub Main
        Exit Sub
    End If
    'get user input
    & vbLf & " " _
        Exit Sub
    End If
    End If
    End If
                Continue For
            End If
        End If
                    Exit Sub
                End If
            End If
            oDrawDoc.Close()
        End If
    Next
                Exit Sub
            Else
            End If
        Else
        End If
    End If
End Sub
    End If
End Function
    Try
            Return False
        End If
            Return True
        Else
            Return False
        End If
        Return False
    End Try
End Function
	Else
	End If
End Function
Labels (3)
3 REPLIES 3
AlexKorzun
in reply to: claudio.ibarra
AlexKorzun
I looked into your code, and there are uses of
FullDocumentName may contain <LODName> , and these <> characters cannot be used in the file/folder names.
So, you may want one of the following:
  • Handle <> depending on whether you want to include LOD name into new path
  • Use .FullFileName, instead of .FullDocumentName
  • Use FileManager.GetFullFileName Method to extract full file name for a Document
Thank you,
Alex Korzun
Inventor-Revit Interop / Inventor-Fusion Interop / Inventor ETO
Thank you,
Alex Korzun
claudio.ibarra
in reply to: AlexKorzun
claudio.ibarra
If I replace FullDocumentName with FullFileName and I still get the error, where else should I look?
AlexKorzun
AlexKorzun
Please inspect other places of the code that generate the file/path names from the contents. For example, the last Function in your code sample (GetRevisionProp) builds the name based on the values from Revision ##.
To narrow down the problem, you may put the MessageBoxes into your code and check whether they appear,  or an exception is thrown first.
There are two functions in .Net world that return illegal characters for the file/path names:
https://docs.microsoft.com/en-us/dotnet/api/system.io.path.getinvalidfilenamechars?view=netframework...
https://docs.microsoft.com/en-us/dotnet/api/system.io.path.getinvalidpathchars?view=netframework-4.8
Thank you,
Alex Korzun
Thank you,
Alex Korzun
