03:18 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have added a leader note with the below code. My questions:
1. How do I create the " sign instead of inch in sText?
2. How can I break the leader note into several lines with text? I want to write something below 1" BSPP.
3. How do I change the leader note text side of each line? Say, if I want the first line to be size 5, and the second line to be size 3.5.
Thanks in advance 😃
'\\\--- ADDS LEADER NOTES ---/// ' Get the mid point of the selected curve ' assuming that the selected curve is linear. ' This is the geometry that the leader text will attach to. Dim oMidPoint As Point2d oMidPoint = aoDrawCurves3SectionViewA(3).MidPoint Dim oLeaderPoints As ObjectCollection oLeaderPoints = ThisApplication.TransientObjects.CreateObjectCollection ' Create a few leader points. Call oLeaderPoints.Add(oTG.CreatePoint2d(oMidPoint.X + 3, oMidPoint.Y+2)) Call oLeaderPoints.Add(oTG.CreatePoint2d(oMidPoint.X + 2, oMidPoint.Y+2)) Call oLeaderPoints.Add(oTG.CreatePoint2d(oMidPoint.X , oMidPoint.Y)) ' Create text with simple string as input. Since this doesn't use ' any text overrides, it will default to the active text style. Dim sText = "1 inch BSPP" Dim oLeaderNote As LeaderNote oLeaderNote = oSheet.DrawingNotes.LeaderNotes.Add(oLeaderPoints, sTexT)
