Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Qty in bom
38 REPLIES 38
Message 1 of 39
GosponZ
8848 Views, 38 Replies
Qty in bom
In Bill of material i have custom PartQty column and is beside QTY column. I need  all informations from QTY column to PartQty column to copy. Possible with iLogic? I'm selecting now manualy copy and paste but it would be nice to have automatic. Could you guys help with please.
Thank you
38 REPLIES 38
Message 2 of 39
Vladimir.Ananyev
in reply to: GosponZ
If you know PartNumber then you may easily get quantity via iLogic function:
quantity = ThisBOM.CalculateQuantity("Model Data", partNumber)
But if your BOM contains overridden quantities then you need to use Inventor API BOMRow.TotalQuantity property for every BOMRow in the BOMView.
(See details here: http://forums.autodesk.com/t5/Inventor-Customization/Exportar-Static-Quantity-da-BOM-para-o-Excel/m-...)
AssemblyDocument ->ComponentDefinition ->BOM->BOMViews->BOMView->BOMRows->BOMRow->TotalQuantity is giving the quantities of the components in the assembly from BOM table.
The following VBA sample illustrates this technique.
Sub GetQuantities()
  ' a reference to the assembly document.
  ' This assumes an assembly document is active.
  Dim oAssyDoc As AssemblyDocument
  Set oAssyDoc = ThisApplication.ActiveDocument
  Dim oAssyDef As AssemblyComponentDefinition
  Set oAssyDef = oAssyDoc.ComponentDefinition
  ' Get the Representations Manager object.
  Dim repMgr As RepresentationsManager
  Set repMgr = oAssyDef.RepresentationsManager
  ' activate LOD Master - necessary to get BOM object !!!
  Dim oMasterLOD As LevelOfDetailRepresentation
  Set oMasterLOD = repMgr.LevelOfDetailRepresentations.Item(1)
  oMasterLOD.Activate
  'set  a reference to the BOM
  Dim oBOM As BOM
  Set oBOM = oAssyDef.BOM
  ' Make sure that the "Parts Only" view is enabled.
  oBOM.PartsOnlyViewEnabled = True
  Call oBOM.SetPartNumberMergeSettings(True)
  'set a reference to the "Parts Only" BOMView
  Dim oBOMView As BOMView
  Set oBOMView = oBOM.BOMViews.Item("Parts Only")
  Dim oBOMRow As BOMRow
  For Each oBOMRow In oBOMView.BOMRows
      'Set a reference to the primary ComponentDefinition of the row
      Dim oCompDef As ComponentDefinition
      Set oCompDef = oBOMRow.ComponentDefinitions.Item(1)
      Dim oPartNumProperty As Property
      Dim oDescripProperty As Property
      Dim Qty As String
      If TypeOf oCompDef Is VirtualComponentDefinition Then
          'Get the Virtual Component property that contains the "Part Number"
          Set oPartNumProperty = oCompDef.PropertySets _
              .Item("Design Tracking Properties").Item("Part Number")
          'Get the  Virtual Component property that contains the "Description"
          Set oDescripProperty = oCompDef.PropertySets _
              .Item("Design Tracking Properties").Item("Description")
          Qty = oBOMRow.TotalQuantity
          Debug.Print oBOMRow.ItemNumber; "  "; oPartNumProperty.value; "  Qty="; _
                      Qty; "  "; oDescripProperty.value
      Else
          'Get the file property that contains the "Part Number"
          'The file property is obtained from the parent
          'document of the associated ComponentDefinition.
          Set oPartNumProperty = oCompDef.Document.PropertySets _
          'Get the file property that contains the "Description"
          Set oDescripProperty = oCompDef.Document.PropertySets _
      End If
  Next
  Beep
End Sub
iLogic function iProperties.Value("ComponentName", "Custom", "PropertyName")   allows you to save any value in the desired custom iProperty:
iProperties.Value("ComponentName", "Custom", "PartQty") = TotalQuantity
or
iProperties.Value("Custom", "PartQty")  = TotalQuantity
Does this help?
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
Message 3 of 39
GosponZ
in reply to: Vladimir.Ananyev
Sorry this no working for me. 😞
As you can see from this picture i just want to have same Qty in PartQty column. So far i'm using copy paste and i'm cool but easier and faster way would be great.
Thank you
Message 4 of 39
Vladimir.Ananyev
Current Inventor API does not expose the BOM.Columns.  So there is no simple way to copy content of one column to another.   But you can do it indirectly copying your data to the appropriate custom iProperties that are exposed in the BOM columns.
So for every BOMRow you should
  • extract source QTY value from this BOMRow object (see my previous post),
  • get the reference to the Inventor Document object corresponding to this row
oDoc = oBOMRow.ComponentDefinitions.Item(1).Document
  • get the reference to the target custom iProperty (PartQty)
  • change iProperty value to Qty and save oDoc
Finally you should update your assembly to refresh its BOM.
Cheers,
Vladimir Ananyev
Message 5 of 39
MisterZs,
I think this is what Vladimir was trying to show you. Put this into an ilogic rule and run it. The key thing is the part number must be the same as the file name of the part. Hope that helps.
doc = ThisDoc.Document
Dim oAssyDef As AssemblyComponentDefinition = doc.ComponentDefinition
Dim oBOM As BOM = oAssyDef.BOM
Dim oBOMView As BOMView = oBOM.BOMViews.Item("Parts Only")
    Dim oPartNumProperty As String
    Dim Qty As String
        oPartNumProperty = oCompDef.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value
    Else
        oPartNumProperty = oCompDef.Document.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value
    End If
    oPartNumProperty &= ".ipt"
    iProperties.Value(oPartNumProperty, "Custom", "PartQty") = Qty
Next
Message 6 of 39
GosponZ
apreciate to All for efort to resolve this problem. I just get this msg. and i run rule. It has error in rule .
Member not found. It doesn't say which member but just not working. I did copy paste into word and then into iLogic.
But hope we are closer.
Thank you
Message 7 of 39
I simplified it and made it not dependant on the part number and file name matching. See how this works. If you are getting the "Not member error", sometimes I notice that Inventor is still holding onto a variable. So just close and restart Inventor and that should correct it. If it doesn't then there's something wrong with the code.
Hope this helps.
    Dim CompFullDocumentName As String = oCompDef.Document.FullDocumentName
    Dim CompFileNameOnly As String
    Dim index As Integer = CompFullDocumentName.lastindexof("\")
    CompFileNameOnly = CompFullDocumentName.substring(index+1)
    'MessageBox.Show(CompFileNameOnly)
    Dim Qty As String
    iProperties.Value(CompFileNameOnly, "Custom", "PartQty") = Qty
Next
Message 8 of 39
GosponZ
Smiley Happy
it is working Thank you so much. Smiley Happy
Message 9 of 39
This is working. Please remember that the "Item("Parts Only")" must be translated if you have language pack in Inventor. (Took me some time to figur it out).
What about other components that ipt? what about iam? How can I count them (not inseparable)? Any ideas? Similar code in the Structure BOM?
This is an issue I'm tyring to solve for over two years. This topic is very close to my case.
Message 10 of 39
The code should still work. You will just need to change "Parts Only" to "Structured" (or the language equivalent). Those are related to the tabs in the BOM. What the code is doing is reading each line in the defined BOM and reading the QTY. Then copying it to a custom iproperties called "PartQTY". So if the part/assembly is Normal, Purchased, or Inseparable it will copy the qty. If it's Reference or Phantom, they won't show in the BOM therefore the QTY is not copied. The only thing with this whole concept that you should be aware of is we are copy the QTY into a custom iProperty. If the part is being used in another assembly and this rule gets run in the other assembly, it will override the current value in the part. Therefore when the original assembly is opened, the PartQty may not match the Qty in that assembly. A thought is to probably append a unique identifier before PartQty like <assemblyname>-PartQty. This way the PartQty will be correct in each assembly but you will have a lot of custom iproperties if the part is used in a lot of assemblies. Some things for you all to think about.
Message 11 of 39
This code will not work. It will count only the assemblies in the first level. And its ok to have custom property (QTY for the moment). I'm not useing Vault so I dont have to check out all files. My rule is launched in the top assembly, searching in every related file the QTY, writing down in customQTY (I will need it in other rules), searching for the drawing and then inserting QTY in the title block. But how to count the assemblies that are used in a few subassemblies?
Let say that I have assembly with two conveyors, A & B. In the main assembly I have 2xA+1xB.
How to count how many H.iam do I need? Each of conveyors contains hangers H.iam (A has 2 hangers but its 2 times in the main assembly so its 2x2 and B has 4 hangers so 4x1) H(QTY)=2x2+4x1=8 H_L.iam is very similar to H.aim, contains the same parts but it's mirrored part do it is welded in a different way. Also has a different QTY because B.iam has 3x H_L.iam. On the end H_L(QTY)=7.
Of course this is an example, in real life this gets more complicated.
I hope you understand my poor language and my big problem. And the screenshot in Polish.
Message 12 of 39
Ahhh...I see. The current code will work for Structured (first level only) and Parts Only. What you are asking for is a little bit more complicated but I think can be done. Let me think about this and will let you know.
Message 13 of 39
Well here's my first crack at this. Not sure I accounted for everything but see how this works. Hope this helps.
Sub Main
Dim oBOMViewPO As BOMView = oBOM.BOMViews.Item("Parts Only")
Dim oBOMRowPO As BOMRow
For Each oBOMRowPO In oBOMViewPO.BOMRows
    oCompDef = oBOMRowPO.ComponentDefinitions.Item(1)
    Dim Qty As String
    Qty = oBOMRowPO.TotalQuantity
Next
If oBOM.StructuredViewEnabled Then
    If oBOM.StructuredViewFirstLevelOnly Then
        oBOM.StructuredViewFirstLevelOnly = False
    End If
Else
    oBOM.StructuredViewEnabled = True
End If
Dim oBOMViewStruc As BOMView = oBOM.BOMViews.Item("Structured")
Dim oBOMRowStruc As BOMRow
Dim arrSubAssemblyList As New ArrayList
Call QueryBOMRowProperties(oBOMViewStruc.BOMRows, arrSubAssemblyList, 1)
End Sub
Private Sub QueryBOMRowProperties(oBOMRows As BOMRowsEnumerator, arrSubAssembly As ArrayList, oParentQty As Integer)
Dim i As Long
For i = 1 To oBOMRows.count
    Dim oBOMRowStruc As BOMRow = oBOMRows.item(i)
    Dim oCompDef As ComponentDefinition = oBOMRowStruc.ComponentDefinitions.item(1)
    Dim oQty As Integer
    If TypeOf oCompDef Is AssemblyComponentDefinition And oCompDef.BOMStructure = BOMStructureEnum.kNormalBOMStructure Then
            oQty = oBOMRowStruc.ItemQuantity * oParentQty
            Dim additionalQty As Integer
            If arrSubAssembly.Count <> 0 Then
                Dim counter As Integer
                For Each CompData As String In arrSubAssembly
                    Dim commaindex As Integer = CompData.indexof(",")
                    Dim CompName As String = CompData.substring(0,commaindex)
                    If CompName = CompFileNameOnly Then
                        additionalQty = CompData.substring(commaindex+1)
                    Else
                        counter += 1
                    End If
                Next
                If additionalQty = 0 Then
                    arrSubAssembly.add(CompFileNameOnly & "," & oQty)
                Else
                    arrSubAssembly(counter) = CompFileNameOnly & "," & oQty + additionalQty
                End If
            Else
            End If
            iProperties.Value(CompFileNameOnly, "Custom", "PartQty") = oQty + additionalQty
            'Recursively iterate child rows if present.
            If Not oBOMRowStruc.ChildRows Is Nothing Then
                Call QueryBOMRowProperties(oBOMRowStruc.ChildRows, arrSubAssembly, oQty)
            End If
        End If
    Next
End Sub
Message 14 of 39
Wow. Big thanks, Dan. It almost worked.
first in the stucture settings I can choose "separator" in your code its comma in my stanrardt it is dot. But the code will fail if someone will choose <none>.
Second thing is more complicated: the code is multipling all levels wchich is good but sometimes I have two machines with the same basic part and the code is writing down only the QTY of last machine.
Please look at the attachment and see if you have the same result (H(QTY)=4 and it should be 8). The tests are run in INV 2013 SP2, WIN7 64bit.
Once again thanks for the efford. I did not know how to get in the BOM structure, I made some tests with exported BOM in excel file, it was mess.
Message 15 of 39
The original code, I was getting 8 for H. I wonder if it's the language is the issue. BTW, I am using Inventor 2014 SP1. But I did notice an index issue and corrected it below. I also changed the separator that my code is using from a comma to a colon. This separator is not the same as the "separator" for the BOM. It should be unrelated. What I am doing is reading each line in the structured BOM and if it's a subassembly then get the name and qty and put it into an array. I am appending the name with a colon and the qty (ex. A.iam:1, B.iam:2, etc). As I am going through each subassembly, I am comparing it to the array that i am building. I ran the following code ont the assembly you gave me and it seems to be working on my end. Try this and let me know how it works.
Sub Main
    Dim Qty As String
    iProperties.Value(CompFileNameOnly, "Custom", "cQty") = Qty
Next
    End If
Else
End If
End Sub
Dim i As Long
    Dim oQty As Integer
                Dim counter As Integer = 0
                    Dim commaindex As Integer = CompData.indexof(":")
                    Else
                        counter += 1
                    End If
                Next
                    arrSubAssembly.add(CompFileNameOnly & ":" & oQty)
                Else
                    arrSubAssembly(counter) = CompFileNameOnly & ":" & oQty + additionalQty
                End If
            Else
            End If
            iProperties.Value(CompFileNameOnly, "Custom", "cQty") = oQty + additionalQty
            End If
        End If
    Next
End Sub
Message 16 of 39
YEAH!
in the earlier version I also had some problem with index, maybe I messed up something trying to run the code (thats why I had the 4 as a result). Now it works like a charm.
I've added the language handeling
Dim PartsOnly As String
Dim Structured As String
Select Case ThisApplication.LanguageName
Case "Polski"
PartsOnly = "Tylko części"
Structured = "Strukturalny"
Case "English"
PartsOnly = "Parts Only"
Structured = "Structured"
End Select
edit:
I made a test with a file with 1247 related files (274 iam) and after 3min of working I had "index problem".
translated from polish: "Index was out of range. Value has to be non-negative and smaller than a size of a collection. Name of a parameter: index".
In the main assembly 2/3 was done correctly but somwhere in the third part something went wrong and the cQTY remain empty. Although in that part which contains cQTY<>0 I had my answer and it's correct.
Message 17 of 39
I tried to find in which part the errors occurs. So I've added Progress bar to see  where the code fails but I handle only the first part, PartsOnly. I'll be graitfull if you coult use this code in further aproaches:
Sub Main
Case "Polski"
Case "English"
End Select
Dim oPart As PartDocument
Dim CollPartList As New Collection
CollPartList = New Collection
Call GetCollPartList(CollPartList, doc) 'all elements .count
Dim i As Long: i = 1
Dim oProgressBar As Inventor.ProgressBar
Dim oBOMViewPO As BOMView = oBOM.BOMViews.Item(PartsOnly)
oProgressBar = ThisApplication.CreateProgressBar(False, CollPartList.Count, "Counting quantity in " & iProperties.Value("Project", "Part Number"))
oProgressBar.Message = "The begining"
    oProgressBar.Message = "Counting .ipt files " & i & "/ " & CollPartList.Count & ": " & CompFileNameOnly
    oProgressBar.UpdateProgress
    Dim Qty As String
    iProperties.Value(CompFileNameOnly, "Custom", "cQty") = Qty '& "PO"
	i+=1
Next
    oProgressBar.Message = "Counting .iam files "&"CLASSIFIED"&" / " & CollPartList.Count & ": "
    End If
Else
End If
Dim oBOMViewStruc As BOMView = oBOM.BOMViews.Item(Structured)
oProgressBar.Close
End Sub
Dim i As Long
    Dim oQty As Integer
                    Else
                        counter += 1
                    End If
                Next
                Else
                End If
            Else
            End If
			'oProgressBar.Message = "Counting  " & i & "/ " & CollPartList.Count & ": " & CompFileNameOnly
    		'oProgressBar.UpdateProgress
            'i+=1
            End If
        End If
    Next
End Sub
Private Sub GetCollPartList(ByRef CollPartList As Collection, oDoc As Document)
'PROGRESS BAR==============================================
On Error Resume Next
Dim el As Document
If oDoc.DocumentType = kAssemblyDocumentObject Then
    For Each el In oDoc.ReferencedFiles
        If el.DocumentType = kAssemblyDocumentObject Then
            GetCollPartList (CollPartList, el)
        End If
        If el.DocumentType = kPartDocumentObject Then
            CollPartList.Add (el, el.FullFileName)
        End If
    Next el
Else
End If
'END PROGRESS BAR=-============================================
End Sub
Message 18 of 39
GosponZ
I just run into problem. Rule is witting very well, but my problem is with Vaoult. We have some library parts in Vaoul and as Library parts can't be edited rule is making iproperties and we can't save or check file in vault. Is it there solution for this problem
Thank you
Message 19 of 39
Now that Vault has come into play, you will have to write an condition statement to check if the file is located in a library path, checked out or if the file attribute is read only. This will have to occur before you write the value into PartQty.
Message 20 of 39
GosponZ
Can you be a little bit more detailed please.
Technology Administrators
