Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Prompted Entry into Symbol Array Drawings
4 REPLIES 4
A.Acheson
622 Views, 4 Replies
A.Acheson
Just wondering is it possible to place  prompted entry into symbol1 prompted entry(), then symbol2prompted entry()  into an array of symbols in order to utilize the same code.
The link shown here uses one prompted entry array for one symbol.
https://forums.autodesk.com/t5/inventor-customization/ilogic-place-sketch-symbol-with-prompted-entry...
I was able to add symbols using an array but failed to add more than one prompted entry array  or indeed unable to place another set of prompted entry into an if statement to choose which symbol each set was added to. There was an error on  this line
Dim sPromptStrings(4) As String
Saying unavailable due to  protection.
Looking to add 5 symbols like this and having 5 rules is a lot of maintenance.
Any help greatly appreciated.
I can post the actually code I used tomorrow.
Regards
Alan
Regards
Alan
Labels (1)
4 REPLIES 4
Michael.Navara
in reply to: A.Acheson
Michael.Navara
You want to use one code base for different sketched symbols with different number of prompts?
A.Acheson
in reply to: Michael.Navara
A.Acheson
@Michael.Navara
Thankyou for your response, correct and different content.
A Sample of what I wanted to happen .
symbol array.......
IF Symbol = “A”
Dim sPromptStrings(0) As String
ElseIf Symbol = “B”
Dim sPromptStrings(1) As String
End If
Dim oSymbol As SketchedSymbol: oSymbol = oSheet.SketchedSymbols.Add(oSymDef, oPosition, , ,sPromptStrings)
The error comes when both prompted strings Dim are entered.
Regards
Alan
@Michael.Navara
symbol array.......
IF Symbol = “A”
ElseIf Symbol = “B”
End If
Regards
Alan
Michael.Navara
Michael.Navara
You can't declare varible twice in one code block. See the following example
'Prepare
Dim Symbol = "B"
Dim sPromptStrings As String()
If Symbol = "A"
	sPromptStrings = {"A"}
ElseIf Symbol = "B"
	sPromptStrings = {"B1", "B2" }
End If
'Debug
Logger.Info(String.Join(vbCrLf,sPromptStrings))
'Prepare
Dim Symbol = "B"
If Symbol = "A"
ElseIf Symbol = "B"
End If
'Debug
A.Acheson
A.Acheson
@Michael.Navara
Thankyou for your response. This worked great. The sample below is the multiple PromptStrings working on seperate symbols.
'Prepare
Dim SymbolList  As New ArrayList
		SymbolList .Add("A")
		SymbolList .Add("B")
		oArray1 = InputListBox("Select one:",SymbolList, "", "iLogic", "Enter Default Answer Here")
Dim Symbol As String
For Each Symbol In SymbolList
		If Symbol = "A"
			sPromptStrings = {"This is Symbol A Message"}
		ElseIf Symbol = "B"
			sPromptStrings = {"This is Symbol B Message-1", "This is Symbol B Message-2" }
		End If
		'Debug
		Logger.Info(String.Join(vbCrLf, sPromptStrings))
		MessageBox.Show("Symbol: "& Symbol, "Title")
		oArray2 = InputListBox("Select one:",sPromptStrings, "", "iLogic", "Enter Default Answer Here")
Next
Regards
Alan
@Michael.Navara
'Prepare
		If Symbol = "A"
		ElseIf Symbol = "B"
		End If
		'Debug
Next
Regards
Alan
