Prompted Entry calculator - how to do?
Hi there,
Im trying to make an macro or something because of the "initial mass" ...
In idw, I do for example 1 peace and then it appears 1.231 kg ... Its ok! 😉 but, now I want the "initial mass", that will calculate my "prompted entrys" before that I call them ( Width, Height, Depth ), each one, I have to introduce the values on it...
The "initial mass" will appear like this: ( "Initial Mass" = Width * Height * Depth * 0,00000785 )
Can someone help me to make this?
Gratefully,
Fred
adam.nagy
Autodesk Support
Autodesk Support
Hi Fred,
It's not completely clear to me what you are trying to do.
Does "Initial Mass" need to be a prompted entry if it depends on Parameters anyway?
Maybe you could provide a most minimal drawing and part file that shows how you are trying to set things up.
Cheers,
Adam Nagy
Autodesk Platform Services
