The code works fine on it's own. I basically change a multi-value parameter between right and drive and left hand drive.
The problem I have is when I then try to change a different parameter.
I begin by defining the parts in the model I want to swap and then what I want to bring in from another folder.
'Define current parts and what to switch with If Drive_Side = "Right Hand Drive" Then RHSCurrentPart = "SSC - RH Idle Sub:1" LHSCurrentPart = "SSC - LH Drive Sub:1" RHSSwitchPart = "SSC - RH Drive Sub.iam" LHSSwitchPart = "SSC - LH Idle Sub.iam"
Else If Drive_Side = "Left Hand Drive" Then RHSCurrentPart = "SSC - RH Drive Sub:1" LHSCurrentPart = "SSC - LH Idle Sub:1" RHSSwitchPart = "SSC - RH Idle Sub.iam" LHSSwitchPart = "SSC - LH Drive Sub.iam" End If 'Replace subs Component.Replace(RHSCurrentPart, SubsLocation & RHSSwitchPart, True) Component.Replace(LHSCurrentPart, SubsLocation & LHSSwitchPart, True)
Everything works fine, but then I change another parameter somewhere else and it reruns the above code.
Now it can't find the RHSCurrentPart, obviously because it's not there anymore because I just switched it out, and I get an error. How do I get it to work properly?
I put a try catch in which worked at first and then randomly stopped working.
Basically if the part is in the browser, run the code after the try, if it doesn't exist, the catch, it skips the block of code.
If Drive_Side = "Right Hand Drive" Then Try Component.IsActive("SSC 02 03 00:1") = True Catch Goto skip End Try RHSCurrentPart = "SSC 02 03 00:1" LHSCurrentPart = "SSC 02 02 00:1" CoverCurrentPart = "SSC 02 00 05:1" RHSSwitchPart = "SSC 02 04 00.iam" LHSSwitchPart = "SSC 02 01 00.iam" CoverSwitchPart = "SSC 02 00 03.ipt" 'Replace side subs Component.Replace(RHSCurrentPart, SubsLocation & RHSSwitchPart, True) Component.Replace(LHSCurrentPart, SubsLocation & LHSSwitchPart, True) Component.Replace(CoverCurrentPart, StretchLocation & CoverSwitchPart, True)
skip:
I ended up putting all my code inside the try, is that the best way to do it?
'Define current parts and what to switch with If Drive_Side = "Right Hand Drive" Then Try RHSCurrentPart = "SSC 02 03 00:1" LHSCurrentPart = "SSC 02 02 00:1" CoverCurrentPart = "SSC 02 00 05:1" RHSSwitchPart = "SSC 02 04 00.iam" LHSSwitchPart = "SSC 02 01 00.iam" CoverSwitchPart = "SSC 02 00 03.ipt" 'Replace side subs Component.Replace(RHSCurrentPart, SubsLocation & RHSSwitchPart, True) Component.Replace(LHSCurrentPart, SubsLocation & LHSSwitchPart, True) Component.Replace(CoverCurrentPart, StretchLocation & CoverSwitchPart, True) InventorVb.DocumentUpdate() Catch Goto skip End Try
I feel that best way would be checking occurrence before replacing components. Try below iLogic code.
Dim oDoc As AssemblyDocument oDoc = ThisApplication.ActiveDocument Dim oDef As AssemblyComponentDefinition oDef = oDoc.ComponentDefinition Dim occ As ComponentOccurrence 'Define current parts and what to switch with If Drive_Side = "Right Hand Drive" Then RHSCurrentPart = "SSC 02 03 00:1" LHSCurrentPart = "SSC 02 02 00:1" CoverCurrentPart = "SSC 02 00 05:1" RHSSwitchPart = "SSC 02 04 00.iam" LHSSwitchPart = "SSC 02 01 00.iam" CoverSwitchPart = "SSC 02 00 03.ipt" For Each occ In oDef.Occurrences If occ.Name = RHSCurrentPart Then 'Replace side subs Component.Replace(RHSCurrentPart, SubsLocation & RHSSwitchPart, True) End If Next For Each occ In oDef.Occurrences If occ.Name = LHSCurrentPart Then Component.Replace(LHSCurrentPart, SubsLocation & LHSSwitchPart, True) End If Next For Each occ In oDef.Occurrences If occ.Name = CoverCurrentPart Then Component.Replace(CoverCurrentPart, StretchLocation & CoverSwitchPart, True) End If Next InventorVb.DocumentUpdate() End If
Please feel free to contact if there are any queries.
Thanks and regards,
