I'm using ILogic to Print multiple pdf's of one idw file, using printmanager & an PDF printer ('PDF Creator')
Now, he prints the files with the idw document name with "_1", "_2", etc. behind the name.
I would like to define in Ilogic the filename he will be using. Anybody know how to define this name?
My PDF printer can use information like 'PrintJobName' als FileName, but I don't know how i can create this information. More options I can use as input for the filename in the PDF printer;
I know how and that it works with 'Save as' instead of 'print', but printing has other advantages I don't want to lose
My current code below. The part between 'Start & Finish first print' I have 5 times in my code.
InventorVb.DocumentUpdate() Dim DocExt = ThisDoc.FileName(False) Dim DocType = DocExt.split("_") Dim oDocDraw As DrawingDocument Dim openDoc As Document Dim docFile As Document openDoc = ThisDoc.Document docFile = ThisDoc.ModelDocument oDocDraw = ThisApplication.ActiveDocument 'format model file name for Iproperties model Dim FNamePos As Long FNamePos = InStrRev(docFile.FullFileName, "\", -1) Dim docFName As String docFName = Right(docFile.FullFileName, Len(docFile.FullFileName) - FNamePos) 'define the property set customPropertySet = docFile.PropertySets.Item("Inventor User Defined Properties") 'define printer settings for TPR format oPrintMgr = ThisApplication.ActiveDocument.PrintManager oPrintMgr.PrintRange = PrintRangeEnum.kPrintAllSheets oPrintMgr.Printer = "PDFCreator" oPrintMgr.PaperSize = kPaperSizeCustom oPrintMgr.PaperHeight = 25 oPrintMgr.PaperWidth = 9 oPrintMgr.Orientation = PrintOrientationEnum.kPortraitOrientation Dim sVariant As String Dim Name1 As String Dim Name2 As String Dim Name3 As String Dim Name4 As String Dim Name5 As String
'Start first print 'Material = A For Each oView In oDocDraw.ActiveSheet.DrawingViews oView.SetDesignViewRepresentation("Material = A", True) Next If DocType(3) = "DxP" Then sVariant = "DAP" Else If DocType(3) = "LxR" Then sVariant = "LAR" End If Name1="TPR"&"_"&iProperties.Value(docFName,"Summary", "Keywords")&"_"&iProperties.Value(docFName,"Project", "Part Number")&"_"&sVariant oPrintMgr.SubmitPrint 'Finish first print
MessageBox.Show(Name1, "Printed Files")
Solved by WCrihfield. Go to Solution.
Unfortunately, going the 3rd party PDF printer route, doesn't allow you to specify the file name within the code.
The PDF Creator software itself, may allow you to manually give the PDF a name before saving it to disc, but the iLogic code to submit the print doesn't know how to talk to that other software.
There are a lot of references here on the forum though, that show you how to export PDF's by other means.
So, when you say "Pring multible PDF of one IDW file", do you mean you want to print each page of the IDW file to its own PDF file?
Wesley Crihfield
(Not an Autodesk Employee)
Hoping that suggestions in the below forum link may be helpful.
https://forums.autodesk.com/t5/inventor-forum/export-multiple-sheets-to-separate-pdf-s/td-p/8303860
Thanks and regards,
Export as PDF unfortunaly creates bad images compared to print as pdf. Therefore I just accept that I have to rename my PDF file names after printer.
He creates now multiple PDF's by calling the PrintJob multiple times, which is possible because the amount and names of views are always the same.
In 2011 version DisplayName drawing property was sent to a printer as "job name". In 2021 it was fixed and now the file name is sent what is not editable.
