Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
print to pdf
4 REPLIES 4
jla9A94K
567 Views, 4 Replies
print to pdf
I'm new to Inventor, and to ilogic. I want to print to pdf. I've found the "PDFAddIn" used for this purpose, but I don't see any documentation for it. How would I as a new user know its there? How do I know how to invoke it? There must be documentation but I cannot find it.
I found on the forum this code which will print to pdf, and which will work for me:
https://forums.autodesk.com/t5/inventor-ilogic-api-vba-forum/pdf-ilogic/m-p/7409690
4 REPLIES 4
A.Acheson
in reply to: jla9A94K
The documentation for the addin are available in the API help. If you look to samples you will find the sample pdf print written in vba code. Have you accessed the help file before?
You can find it in the ribbon under help>programming api help. Type in the search bar pdf print and you when the .chm file appears.
Regards
Alan
jla9A94K
That is the answer to my question but I do not see how to open the API help. The only interface I can see is when I go to add a rule or edit a rule from Inventor... I don't see a help menu here? Perhaps I have not installed a component... or I'm just plain missing it.
A.Acheson
It isn’t near the ilogic editor unfortunately. In the main ribbon under help or the ? Symbol.
here is a link to an image.
http://inventortrenches.blogspot.com/2013/10/ilogic-how-to-learn-inventors.html?m=1
It is also available online but for some reason all autodesk help files are down at the moment.
Regards
Alan
jla9A94K
I see it now.
Thank you for the help!
