Hi all,
My pring to pdf i-logic shows an error when printing to pdf since upgrading to Inventor 2018.
Has anyone had this error message and how did you fix it?
Code attached below;
thanks in advance
SyntaxEditor Code Snippet
Dim PDFAddIn As TranslatorAddIn PDFAddIn = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}") 'Set a reference to the active document (the document to be published). Dim oDocument As Document oDocument = ThisApplication.ActiveDocument Dim oContext As TranslationContext oContext = ThisApplication.TransientObjects.CreateTranslationContext oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism ' Create a NameValueMap object Dim oOptions As NameValueMap oOptions = ThisApplication.TransientObjects.CreateNameValueMap ' Create a DataMedium object Dim oDataMedium As DataMedium oDataMedium = ThisApplication.TransientObjects.CreateDataMedium ' Check whether the translator has 'SaveCopyAs' options If PDFAddIn.HasSaveCopyAsOptions(oDataMedium, oContext, oOptions) Then oOptions.Value("All_Color_AS_Black") = 1 oOptions.Value("Remove_Line_Weights") = 0 oOptions.Value("Vector_Resolution") = 4800 oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets 'oOptions.Value("Custom_Begin_Sheet") = 2 'oOptions.Value("Custom_End_Sheet") = 4 End If PDFDirectory = ThisDoc.Path oFileName = ThisDoc.FileName(False) 'without extension If ThisDoc.Path = "" Then MessageBox.Show("PDF file not created, click Save button again for PDF creation.", "iLogic") Return 'exit rule Else oDataMedium.FileName = PDFDirectory & "\" & oFileName & ".PDF" End If 'Publish document. PDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium) 'Launch the PDF file in whatever application Windows is set to open this document type with 'i = MessageBox.Show("Preview the PDF file?", "PDF Preview",MessageBoxButtons.YesNo,MessageBoxIcon.Question) 'If i = vbYes Then ThisDoc.Launch(oDataMedium.FileName)
Solved by JaneFan. Go to Solution.
Please try to change one argument in method HasSaveCopyAsOptions(), using Document instead of DataMedium.
If PDFAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then
