Presentation - Hide / Show Trails
10 REPLIES 10
Message 1 of 11
d_stockinger
1093 Views, 10 Replies
I would like to hide / show all Trails via API.
Tried it with the "PresentationExplodedViews" Object, but there is the Trail Visibility is a read only Object.
Is there a way to get access via API?
Regards
Daniel
10 REPLIES 10
Message 2 of 11
HideoYamada
in reply to: d_stockinger
Hello Daniel,
I tried to change the visibility of the trails, but couldn't.
There are undocumented APIs such as PublicationTweak or PublicationTrailSegment.
I found that PublicationTrailSegment.Visible is related to the visibility of the Trail, but it seems to be read-only.
Sub ChangeAllTrailVisibility(Optional showTrail As Boolean = True)
    Dim oPrDoc As PresentationDocument
    Set oPrDoc = ThisApplication.ActiveDocument
    Dim oBNs As BrowserNodesEnumerator
    Set oBNs = oPrDoc.BrowserPanes(1).TopNode.BrowserNodes(1).BrowserNodes(2).BrowserNodes
    Dim oBN As BrowserNode
    For Each oBN In oBNs
        If TypeOf oBN.NativeObject Is PublicationTweak Then
            Dim oPT As PublicationTweak
            Set oPT = oBN.NativeObject
            Dim oPTSeg As PublicationTrailSegment
            For Each oPTSeg In oPT.TrailSegments
                ' PublicationTrailSegment.Visible can be read.
                Debug.Print oPTSeg.Visible
                ' But we cannot write on it.
                'oPTSeg.Visible = showTrail
            Next oPTSeg
        End If
    Next oBN
End Sub
So I think that we cannot change the visibility of the trails.
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
https://www.freeradical.jp
Message 3 of 11
d_stockinger
in reply to: HideoYamada
Hello Hideo,
Thanks for your Answer.
In the meantime I found an object in the Inventor Api Help that can affect the visibility of the path segment.
Found the object in the Inventor API object model but can not get back any path segments.
Here is a Screenshot from a Watch in VBA
VBA Code:
Public Sub Test()
Dim PresDoc As PresentationDocument
Set PresDoc = ThisApplication.ActiveDocument
Dim Scene As PresentationScene
Set Scene = PresDoc.Scenes(1)
Dim SnapShot As PresentationSnapshotView
Set SnapShot = Scene.SnapshotViews(1)
'Dim Trails As PresentationTrails
'Set Trails = SnapShot.Trails
End Sub
Regards
Daniel
Message 4 of 11
@d_stockinger,
Thanks for writing it in forum,
I tried to set hide or show trail using below VBA code. Fails to set value for PresentationTrailSegment.Visible Property.
Public Sub Test()
    Set Trails = SnapShot.Trails.Item(9)
    Trails.Segments.Item(1).Visible = False
End Sub
To address this, a change request (INVGEN - 35227) is created with engineering team.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Message 5 of 11
@chandra.shekar.g
Thanks for your time to test this usecase.
Is there any timeframe for this fix?
Regards
Daniel
Message 6 of 11
@d_stockinger,
I will let you know once it is implemented.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 7 of 11
YuhanZhang
Hi Daniel,
Do you want to hide the trails in the storyboard or in a snapshot view? As you can see the current API PresentationSnapshotView.Trails only returns the trails in a PresentationSnapshotView, we have not exposed the API for storyboard yet, so if you want to hide all the trails in the storyboard it would be a new wish for us. I just want to check if we implement the PresentationTrailSegment.Visible as R/W can help you or not.
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
Message 8 of 11
d_stockinger
in reply to: YuhanZhang
Hello Rocky,
thanks for you replay.
For shure it would be nice to hide all Trails in the StoryBoard, but if I can hide the Trails via Snapshot, I can iterate programmatically through all snapshots. So for me the snapshot is enough.
Daniel
Message 9 of 11
YuhanZhang
Thanks Daniel, this will help us to estimate this requirement.
Rocky Zhang
Inventor API PD
Autodesk, Inc.
Message 10 of 11
YuhanZhang
Hi Daniel,
In Inventor 2021 you can try below VBA to see if it works for you:
Sub TurnOffTrailsInSnapshotView()
Dim oPresDoc As PresentationDocument
Set oPresDoc = ThisApplication.ActiveDocument
Dim oScene As PresentationScene
 Set oScene = oPresDoc.Scenes(1)
Dim oSnapShot As PresentationSnapshotView
 Set oSnapShot = oScene.SnapshotViews(1)
' we need to break the associativity between the snapshot view and storyboard before editing it
oSnapShot.StoryboardAssociative = False
' enter the edit mode for snapshot view(eitherwise the edit will fail)
oSnapShot.Edit
Dim oTrail As PresentationTrail
For Each oTrail In oSnapShot.Trails
    Dim oSeg As PresentationTrailSegment
    For Each oSeg In oTrail.Segments
        Debug.Print oSeg.Visible
        oSeg.Visible = False
    Next
Next
End Sub
Rocky Zhang
Inventor API PD
Autodesk, Inc.
Message 11 of 11
d_stockinger
Hello Rocky,
Thank you so much. It works now as expected in Inventor 2021.
Regards
Daniel
Technology Administrators
