PDF TranslatorAddIn options
3 REPLIES 3
aales
738 Views, 3 Replies
I am using Inventor 2011. When I display dialog with options for export to PDF in Inventor, all options in this dialog I can set programatically except one - something like Print excluded sheets(I translate it to English from Czech version). This option is accessible when PrintAllSheets or PrintSheetRange option is set.
I can't find it in option values list for PDF in help file. Is it only undocumented or is it not accesible programatically?
Thanks for answers
3 REPLIES 3
xiaodong_liang
in reply to: aales
The sample of the help doc has indicated the options.
' Check whether the translator has 'SaveCopyAs' options
    If PDFAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then
        ' Options for drawings...
        oOptions.Value("All_Color_AS_Black") = 0
        'oOptions.Value("Remove_Line_Weights") = 0
        'oOptions.Value("Vector_Resolution") = 400
        'oOptions.Value("Sheet_Range") = kPrintAllSheets
        'oOptions.Value("Custom_Begin_Sheet") = 2
        'oOptions.Value("Custom_End_Sheet") = 4
    End If
aales
in reply to: xiaodong_liang
I know this part of the help topic. But in the dialog box for PDF is one more option - checkbox Print excluded sheets. (The same checkbox for printing is PrintExcludedSheets property in DrawingPrintManager object in API).
Is this option for PDF accessible programmatically or not?
xiaodong_liang
in reply to: aales
I was told that this option has not been exposed. Sorry.
probably you could use PDF API to exclude the pages after Inventor produces the PDF.
Technology Administrators
