Hi, I'm trying to push parameters from to iam and made them edible, is this doable?
Solved by A.K.CORTEL. Go to Solution.
Hi @A.K.CORTEL
It won't be possible to drive linked parameters like that as that is a bottom up workflow. You can drive them from top down through ilogic. Can you share an example of how you manually are currently doing this? Include images of the parameter window and browser.
My thought is if it would possible to drive linked parameters without including the top down ipt to the master iam.
Manual method. Place skeleton .ipt into .iam, edit skelton and update.
Ilogic method
Place skeleton .ipt into .iam. Drive parameter from the assembly parameter.
Parameter("Skeleton:1","Param1") = Param1
See help page here for this function
Thanks Acheson,I'm familiar with the snipping you provide and the method.
To your knowledge is there any code that can copy paste parameters?
Not exactly copy and paste but sort of. Go into the ilogic editor, open your skelton part in the browser and the parameters list, highlight the parameters and right click capture parameter value. This should give you the parameter function and its value from the assembly level. It should only be a matter of assigning a parameter value to the parameter function.
Definitely quicker than typing it all out.
