Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Parameter return values
1 REPLY 1
NachitoMax
167 Views, 1 Reply
Hey
i need to get for length formats from some parameters in code regardless of the input length type. Lets say i am entering 100 in as a string value to the parameter expression, the 4 return values i need back are:
A. 8' 4"
B. 8.3333 ft
C. 254 cm
D. 2540 mm
i can get the correct values from B, C & D but not 8. I can get it back in inches or decimal foot but not fraction. Is there an alternative way to convert into a fractional using inventor parameters? I need the same 4 results returned irrespective of the input i.e. if i entered 2540 mm, i would still get the same 4 results back.
im doing this in code btw
Nacho
Automation & Design Engineer
Inventor Programmer (C#, VB.Net / iLogic)
1 REPLY 1
NachitoMax
in reply to: NachitoMax
Couldnt find an inventor method using vb.net, everything converts to decimal feet so i converted the input value to decimal feet then used this to convert to fractional feet
Private Function GetFractionFeet(ByVal DecimalLength As Double) As String
            Dim n64 As Integer = Math.Abs(CInt(Math.Round(DecimalLength * 12 * 64, 0)))
            Dim feet As Integer = n64 \ 64 \ 12
            Dim inches As Integer = n64 \ 64 - feet * 12
            Dim f64 As Integer = n64 Mod 64
            Dim fraction As String = ""
            If f64 > 0 Then
                Dim denom As Integer = 64
                Do While f64 Mod 2 = 0
                    f64 \= 2
                    denom \= 2
                Loop
                fraction = f64.ToString & "/" & denom.ToString & " "
            Dim sign As String = If(DecimalLength < 0, "-", "")
            Return String.Format("{0}{1}' {2}{3}""", sign, feet, inches, fraction)
        End Function
Nacho
Technology Administrators
