Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Override color asset on face - HRESULT: 0x80020003 (DISP_E_MEMBERNOTFOUND)
1 REPLY 1
544 Views, 1 Reply
I wanted to make iLogic rule to change color of selected face in Part.
	Dim oPartDoc As PartDocument
	oPartDoc = ThisApplication.ActiveDocument
'	Dim userParams As UserParameters
'	userParams = oPartDoc.ComponentDefinition.Parameters.UserParameters
'	Dim param As Parameter
	Dim oAsset As Asset
	Dim oAssets As Assets
	oAssets = oPartDoc.Assets
	Dim kolWew As Asset
	Dim kolWewNazwa As String
	kolWewNazwa = "RAL1001_Beige"
	Dim kolZew As Asset
	Dim kolZewNazwa As String
	kolZewNazwa = "RAL6018_Yellow_green"
	Try
		kolWew = ThisApplication.AssetLibraries.Item("RAL_Colors").AppearanceAssets.Item(kolWewNazwa).CopyTo(ThisDoc.Document, True)
	Catch
		kolWew = oPartDoc.Assets.Item(kolWewNazwa)
	End Try
	Try
		kolZew = ThisApplication.AssetLibraries.Item("RAL_Colors").AppearanceAssets.Item(kolZewNazwa).CopyTo(ThisDoc.Document, True)
	Catch
		kolZew = oPartDoc.Assets.Item(kolZewNazwa)
	End Try
'	While True
		oFace = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAllEntitiesFilter, "Wskaż powierzchnie zewnętrzne")
		oFace.Appearance = kolZew
'	End While
The problem is in line:
This give me error "HRESULT: 0x80020003 (DISP_E_MEMBERNOTFOUND)". I didn't found the solution to this problem for Assets. I also used "Help" in Inventor, but it didn't not help that. Compared to examples in "Help", everything looks correct.
Is there any other functions to allow override the color on any selected faces in part?
Thanks in advance
1 REPLY 1
wolfgang_nickl
try to insert a
dim oFace as Face
	Dim oAsset As Asset
	Dim kolWew As Asset
	Dim kolZew As Asset
	Try
	Catch
	End Try
	Try
	Catch
	End Try
	Dim oFace as Face
' While True oFace = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAllEntitiesFilter, "Wskaż powierzchnie zewnętrzne") oFace.Appearance = kolZew ' End While
Best Regards
Wolfgang
Technology Administrators
