I can't figure out how to add items to an object collection in a specific order. How do you do it? Is it possible? Do I need to use arrays instead? I need the front view to always be the first item and so on.
Dim oReturnColl(1 To 3) As ObjectCollection
For Each DrawingView In oSheet.DrawingViews
Select Case oSheet.DrawingViews.item(i).Type
Case ViewOrientationTypeEnum.kBackViewOrientation
Case ViewOrientationTypeEnum.kBottomViewOrientation
Case ViewOrientationTypeEnum.kFrontViewOrientation
oReturnColl.item(1) = DrawingView
CurrentScale = oSheet.DrawingViews.item(i).Scale
Case ViewOrientationTypeEnum.kIsoBottomLeftViewOrientation
Case ViewOrientationTypeEnum.kIsoBottomRightViewOrientation
Case ViewOrientationTypeEnum.kIsoTopLeftViewOrientation
Case ViewOrientationTypeEnum.kIsoTopRightViewOrientation
Case ViewOrientationTypeEnum.kLeftViewOrientation
oReturnColl.item(2) = DrawingView
Case ViewOrientationTypeEnum.kRightViewOrientation
Case ViewOrientationTypeEnum.kTopViewOrientation
Case Else
oReturnColl.item(3) = DrawingView
End Select
Next
i = i + 1
Solved by inulobo. Go to Solution.
Maybe:
Dim oDrawingView As DrawingView
For Each oDrawingView In oSheet.DrawingViews
Select Case oDrawingView.Type
oReturnColl.item(1) = oDrawingView
CurrentScale = oDrawingView.Scale
oReturnColl.item(2) = oDrawingView
Case Else
oReturnColl.item(3) = oDrawingView
End Select
Next
try again
I'm not sure what your end goal is since this is only part of you code, but in order to use an object collection, you need to add all objects and the sort them. A NameValueMap lets you collection Objects with a unique Key attached to each of them, this means the Object/Key can be retrieved by searching with the other.
Either way you need to create them before you can fill them, so let me know if either route works for your purposes:
'ObjectCollections collect as a running list. If you want it sorted, it can be done after collection
Dim oReturnColl As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection
'NameValueMaps collect items with an associated unique Key
Dim oReturnMap As NameValueMap = ThisApplication.TransientObjects.CreateNameValueMap
Select Case DrawingView.Type
Try
oReturnMap.Add("1", DrawingView) 'NameValueMap.Add(Unique Name, Object)
Catch
'Key is already used
End Try
oReturnColl.Add(DrawingView) 'ObjectCollection.Add(Object)
Try
oReturnMap.Add("2", DrawingView) 'NameValueMap.Add(Unique Name, Object)
Catch
End Try
Case Else
Try
oReturnMap.Add("3", DrawingView) 'NameValueMap.Add(Unique Name, Object)
Catch
End Try
End Select
Next
I put the NameValueMap setting into a Try/Catch Block because if you have 2 views on your sheet that are both "ViewOrientationTypeEnum.kFrontViewOrientation", you need a unique key for each.
Let me know if you have any questions or if this is not working as intended.
I believe your solution is iLogic I am working in vba in particular. I did come up with a solution last night !
Dim oReturnColl As Collection
Set oReturnColl = New Collection
Select Case oSheet.DrawingViews.item(i).Camera.ViewOrientationType
oReturnColl.Add DrawingView
oReturnColl.Add (DrawingView), After:=1
Case Else
oReturnColl.Add (DrawingView), After:=2
End Select
Next
i = i + 1
