I'm having a specific issue when using ordinate dimensions.
Firstly, I am placing an ordinate dimension set based of a collection of centerlines.
Set oCLCol = SortAngledCLCollection(oCLCol, "V")
For Each oCL In oCLCol
If oCL.StartPoint.Y > oCL.EndPoint.Y Then
Set oAttachPoint1 = oCL.StartPoint
Else
Set oAttachPoint1 = oCL.EndPoint
End If
Set oAttachPoint1 = ThisApplication.TransientGeometry.CreatePoint2d(oAttachPoint1.X, oAttachPoint1.Y)
Set oIntent1 = oSheet.CreateGeometryIntent(oCL, oAttachPoint1)
Call oIntentCol.Add(oIntent1)
Next
Set oAttachPoint1 = ThisApplication.TransientGeometry.CreatePoint2d(oDrawView.Center.X, oDrawView.Center.Y + oDrawView.Height)
Call oSheet.DrawingDimensions.OrdinateDimensionSets.Add(oIntentCol, oAttachPoint1, kAlignedToCurveDimensionType)
When I try to go given a centerline and match up weather or not the centerline has a ordinate dimension it doesn't seem to find it. When I delete the member from the set and add it manually back to the set the intent is found. But for some reason when I add them through the above code it doesn't seem to find the intent. I just wander if I am doing something odd. I have also tried to remove the "oAttachPoint1" to the create geometry and it still didn't seem to work and created a dim at each end of the centerline which is not what I'm wanting. This is rough code definitely not finished.
Below is what I was trying to put together to find the intent based off of the above set added to my drawing view. I'm manually selecting the centerline on the drawing view that has an ordinate dimension already attached. The purpose of this entire check is to make sure I am not duplicating ordinate dimensions. I'm creating ordinate dimension set automation and want to not cause duplication or dimensions on top of dimensions.
Public Sub OrdinateDimTest()
Dim oCLIn As Centerline: Set oCLIn = ThisApplication.CommandManager.Pick(Inventor.SelectionFilterEnum.kDrawingCenterlineFilter, "Select a Centerline.")
Dim oIntentIn As GeometryIntent
Dim oIntentIn2 As GeometryIntent
Dim oAttachPoint1 As Point2d
Dim oAttachPoint2 As Point2d
Dim oWorkFeatureIn As Object
Dim oOccIn As ComponentOccurrence
Dim strFamIn As String
Dim oDrawDoc As DrawingDocument: Set oDrawDoc = ThisApplication.ActiveDocument
Dim oSheet As Sheet: Set oSheet = oDrawDoc.ActiveSheet
Dim oDrawDims As DrawingDimensions: Set oDrawDims = oSheet.DrawingDimensions
Dim oOrdDimSets As OrdinateDimensionSets: Set oOrdDimSets = oDrawDims.OrdinateDimensionSets
Dim oOrdDimSet As OrdinateDimensionSet
Dim oMembers As OrdinateDimensionsEnumerator
Dim oMember As OrdinateDimension
Dim oIntent As GeometryIntent
Dim oCL As Centerline
Dim oWorkFeature As Object
Dim oOcc As ComponentOccurrence
Dim oOccDoc As Document
Dim strFam As String
Dim blnAddMember As Boolean
Dim oOrdDims As OrdinateDimensions: Set oOrdDims = oDrawDims.OrdinateDimensions
Dim oOrdDim As OrdinateDimension
If oCLIn.StartPoint.Y > oCLIn.EndPoint.Y Then
Set oAttachPoint1 = oCLIn.StartPoint
Else
Set oAttachPoint1 = oCLIn.EndPoint
End If
Set oIntentIn = oSheet.CreateGeometryIntent(oCLIn, oCLIn.StartPoint)
Set oIntentIn2 = oSheet.CreateGeometryIntent(oCLIn, oCLIn.EndPoint)
For Each oOrdDim In oOrdDims
Set oIntent = oOrdDim.Intent
If oIntent.Geometry Is oIntentIn.Geometry Then
Debug.Print "Here"
End If
If oIntent.Geometry Is oIntentIn2.Geometry Then
Debug.Print "Here"
End If
Next
End Sub
Tiffany Hayden
Solved by Tiffany_Hayden_. Go to Solution.
Hi @Tiffany_Hayden_. Have you tried checking the GeometryIntent.IntentType to see if it is a geometry based intent? If not, then the GeometryIntent.Geometry property will return Nothing. And if the intent type is Point2d type, you could use the GeometryIntent.PointOnSheet property to get that Point2D object from the intent.
Wesley Crihfield
(Not an Autodesk Employee)
@WCrihfield I guess my concern is that I may not be adding the OrdinateDimensionSet correctly which is causing me not to find the intents associated with them.
Tiffany Hayden
@WCrihfield The odd thing that I have found is that if I delete the member and add the member back clicking on the CL I'm using and then run my code to find the intent it is found no issue. So that points to the way I'm adding the OrdinateDimensionSet as being incorrect. 😞
Tiffany Hayden
I even tried this
Set oAttachPoint2 = ThisApplication.TransientGeometry.CreatePoint2d(oCL.StartPoint.X, oCL.StartPoint.Y)
Set oIntent1 = oSheet.CreateGeometryIntent(oCL, oAttachPoint2)
Next
Still no intent was found.
Set oAttachPoint2 = ThisApplication.TransientGeometry.CreatePoint2d(oCLIn.StartPoint.X, oCLIn.StartPoint.Y)
Set oIntentIn = oSheet.CreateGeometryIntent(oCLIn, oAttachPoint2)
Debug.Print "Here"
End If
Next
end Sub
Tiffany Hayden
Quick question...Why are you creating a new transient Point2D, based on the X & Y coordinates of the Centerline.StartPoint, instead of just using the Centerline.StartPoint directly, since it is already a Point2D type object? Maybe that slightly more direct association is what is needed. Another question...is this 'picked' OrdinateDimension part of an OrdinateDimensionSet, or have you specified an Origin for the DrawingView that the individual OrdinateDimensions are being referenced from? I'm not 100% sure if it matters, but I'm pretty sure that the 'first' GeometryIntent that you supply in a set of them, when creating an OrdinateDimensionSet seems to be more important than the others, so maybe the first one is the only one that is really associated with 'geometry' while the others may just be Point2d based, I'm not sure. I haven't done a ton of drawing dimension automation projects, because of the vast variety/diversity of stuff we make drawings for.
Wesley Crihfield
You should create the geometry intent from the centerline, using
PointIntentEnum.kStartPointIntent
Or
PointIntentEnum.kEndPointIntent
As the second argument.
Example:
For Each oCL In oCLCol Dim oIntent As GeometryIntent If oCL.StartPoint.Y > oCL.EndPoint.Y Then Set oIntent = oSheet.CreateGeometryIntent(oCL, PointIntentEnum.kStartPointIntent) Else Set oIntent = oSheet.CreateGeometryIntent(oCL, PointIntentEnum.kEndPointIntent) End If Call oIntentCol.Add(oIntent) Next
Jhoel Forshav
Download my free Inventor Addin - Hole Projector
LinkedIn | Ideas | Contributions | Blog posts | Website
It looks like the problem I was having was a corrupt drawing view. After I deleted the drawing view and recreated it and ran my code it worked fine.
Tiffany Hayden
@JhoelForshav Thank you for the information. I didn't know that that was an option. It didn't fix the problem but I will use that! I had a corrupt drawing view that needed to be recreated. Guess it got tired of the automation I was throwing at it. Thanks again, have a great day!
Tiffany Hayden
