Are you trying to do this programmatically? If not you should be asking in
the Inventor Support NG instead of the VBA NG.
You should be able to set up multiple dimension styles and pick which one to
use in the dropdown in the IDW as you go.
Kent Keller
"BarnaMadau" wrote in message
news:f0b8afd.-1@WebX.maYIadrTaRb...
> How can I make some dimensions decimal and other fractional in one
ordinate dimension set. For example, I could be dimensioning holes that are
three decimal basic, and down the line there could be part edges or
non-critical cut-outs that could be fractional (plus or minus 1/64").
