Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Not geting the same DrawingView from parent
0 REPLIES 0
Message 1 of 1
166 Views, 0 Replies
Hallo.
I get some strange behavior in my code.
The idea was to have this code delete all bend notes in a drawing view of a flat pattern. but it dose not work. It's like the DrawingCurve.Parent is returning different drawing view, then the one i picked at the start.
I have solved this by using Reference Keys from the drawing view and comparing them.
So I´m just wondering if I´m missing something or is this intend behavior?
  Dim DrawingView As Inventor.DrawingView
  DrawingView = m_inventor.CommandManager.Pick(Inventor.SelectionFilterEnum.kDrawingViewFilter, "Pick")
    If DrawingView IsNot Nothing Then
        Dim Sheet As Sheet
        Sheet = DrawingView.Parent
        Dim DrawingDocument As Document
        DrawingDocument = Sheet.Parent
        Dim ReferencedDocument As Document
        ReferencedDocument = DrawingView.ReferencedDocumentDescriptor.ReferencedDocument
        Dim ComponentDefinition As ComponentDefinition
        ComponentDefinition = GetComponentDefinition(ReferencedDocument)
        If TypeOf ComponentDefinition Is SheetMetalComponentDefinition Then
            Dim BendNotes As BendNotes
            BendNotes = Sheet.DrawingNotes.BendNotes
            For Each BendNote In BendNotes.Cast(Of BendNote)
                Dim DrawingCurve As DrawingCurve
                DrawingCurve = BendNote.BendEdge
                ' For some reason this donse not return same drawing view that was used as input.
                Dim ParentDrawingView As DrawingView
                ParentDrawingView = DrawingCurve.Parent
                If DrawingView = ParentDrawingView = True Then
                    BendNote.Delete()
                End If
            Next
            Document.Update()
        End If
    End If
0 REPLIES 0
Technology Administrators
