Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
No New project
4 REPLIES 4
158 Views, 4 Replies
No New project
I'am a newbe (to VBA) and am going through the Introduction to VBA/API
Tutorial on Point A. On my home system, when I Select File > New Project,
nothing happens. On my work system, when I Select File > New Project, it
adds (UserProject1) just like it suppost to. The two systems where set up
the same from the Inventor install CD. Anyone have any ideas what the
problem (at home) might be?
TIA
Rick
4 REPLIES 4
Glad to see I am not the only one that has that problem. I haven't been able to figure it
out, hoping the 5.3 install will fix it though.
Kent
"Rick Donnellon" wrote in message
news:D1DF5C0B5649E4BB8395F370721F2316@in.WebX.maYIadrTaRb...
> TIA
> Rick
This same problem was reported earlier this week in an API training class.
After a bit of investigation we discovered the cause of the problem. If you
don't have the directory "C:\Temp" the creation of new VBA projects fails.
This is a defect that we'll fix, but for now just create "C:\Temp" and you
should be ok.
-Brian
> TIA
> Rick
Can't try it until tonight, but I bet my life just got easier. 8^) Thanks
Kent
"Brian Ekins" wrote in message
news:7DADF251E277165620E206F81095E3CB@in.WebX.maYIadrTaRb...
> should be ok.
> -Brian
I can't either but at work here, I renamed my C:\temp and then tried to
start a new project and got exactly what I get at home so I'm sure this will
fix it..
Thanks for the tip Brian ;^)
Rick
"Kent Keller" wrote in message
news:BCB145A70B40B799E861B16133DA6B8E@in.WebX.maYIadrTaRb...
> Kent
class.
you
fails.
you
> > should be ok.
> > -Brian
Technology Administrators
