12:29 PM
- Mute
- Permalink
- Report
Can the text placement of a radius or diameter 3D dimension be changed after it has been placed?
I can get the coordinates of a given dimension's text easy enough, but can't figure out how to reposition it.
I tried changing the TextPosition.(XYZ) properties directly, or using the PutPointData method, but the dimension remains unchanged.
And maybe the question I should be asking is:
Is there a way to place leader based 3D dimensions that prevents them from flying off into the void as a part updates due to parameter changes?
