Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Modify path of a Sweep
2 REPLIES 2
KenPalAlt
125 Views, 2 Replies
I have figured out how to create a new sweep, but I can't figure out how to modify the path of an existing one (using existing sketches).
See function UpdateSweep() in the code below.
Class Sweep
	Dim oDoc As PartDocument
	Dim oCompDef As ComponentDefinition
	Dim oFeats As PartFeatures
	Dim oSweepFeats As SweepFeatures
	Sub Main
		oDoc = ThisDoc.Document
		oCompDef = oDoc.ComponentDefinition
		oFeats = oCompDef.Features
		oSweepFeats = oFeats.SweepFeatures
		If FeatureExists("MySweep") Then oFeats("MySweep").Delete
		Call MakeNewSweep("MySweep", "ProfileSketch", {"PathSketch1", "PathSketch2"})
		Call UpdateSweep("MySweep", "ProfileSketch", {"PathSketch1", "PathSketch2", "PathSketch3"})
	End Sub
	Sub MakeNewSweep(sweepName As String, profileSketchName As String, pathSketchNames As String())
		Dim oProfileSketch As Sketch = oCompDef.Sketches.Item(profileSketchName)
		Dim oProfile As Profile = oProfileSketch.Profiles.AddForSolid
		Dim oPath As Path = CreateSketchCurvesPath(pathSketchNames)
		Dim oSweep As SweepFeature = oCompDef.Features.SweepFeatures.AddUsingPath(oProfile, oPath, kJoinOperation)
		oSweep.Name = sweepName
	End Sub
	Sub UpdateSweep(sweepName As String, profileSketchName As String, pathSketchNames As String())
		Dim oSweepFeat As SweepFeature = oSweepFeats(sweepName)
		Dim oSolidSweepDef As SolidSweepDefinition = oSweepFeat.SolidSweepDefinition
		Logger.Info(oSweepFeat.Name) 'Displays correct Sweep
		Logger.Info(oSolidSweepDef) ' Empty! Can't figure out how to use oSweepFeats.CreateSolidSweepDefinition()
		Logger.Info(oPath.Count) 'Displays new path count
		'[ No idea where to proceed from this
		Dim sweepType As SweepTypeEnum = kPathSweepType
		Dim partFeatureOperationEnum As PartFeatureOperationEnum = kJoinOperation
		Dim oNewSweepDef As SweepDefinition = oSweepFeats.CreateSweepDefinition(sweepType, oProfile, oPath, partFeatureOperationEnum)
		Logger.Info(oNewSweepDef.Path.Count)
		' This throws error "Object reference not set to an instance of an object." since oSolidSweepDef is empty
		oSolidSweepDef.Path = oPath
	End Sub
	Function CreateSketchCurvesPath(pathSketchNames As String()) As Path
		Dim oColl As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection
		For Each pathSketchName In pathSketchNames
			Dim oPathSketch As Sketch = oCompDef.Sketches.Item(pathSketchName)
			Dim oSketchPaths As Path = oFeats.CreatePath(oPathSketch.SketchLines(1))
			For Each oPathEntity In oSketchPaths
				Dim oSkEntity As SketchEntity
			        oSkEntity = oPathEntity.SketchEntity
					Call oColl.Add(oSkEntity)
			Next
		Next
		Dim oPath As Path = oFeats.CreateSpecifiedPath(oColl)
		Return oPath
	End Function
	Function FeatureExists(featureName As String) As Boolean
		For Each oFeat In oFeats
			If oFeat.Name = featureName Then Return True
		Next
		Return False
	End Function
End Class
Labels (1)
2 REPLIES 2
cidhelp
in reply to: KenPalAlt
Hello @KenPalAlt ,
you created a SweepDefinition-Object, not a SolidSweepDefinition. You have to edit this SweepDefinition. Also the logger needs a string-argument.
See my edits:
KenPalAlt
in reply to: cidhelp
Thanks, works great!
Posting the corrected code in case someone finds this later:
Class Sweep
	Sub Main
	End Sub
	End Sub
		Dim oSweepDef As SweepDefinition = oSweepFeat.Definition
		oSweepDef.Path = oPath
	End Sub
			Next
		Next
		Return oPath
	End Function
		Next
		Return False
	End Function
End Class
