Modify HoleThreadNotes
pveng
pveng
Hello all,
I wanted to add information on holethreadnotes with:
    oHole.FormattedHoleThreadNote = "Additional information" & oHole.FormattedHoleThreadNote
With this command, the button "Toleranzen" is automatically checked, see picture below. If the method property is set to "symmetric" there will appear a "+-" sign behind of the note, what I want to avoid.
My question: Is it possible to uncheck the button "Toleranzen" with VBA-Code?
Thanks in advance,
pveng
frederic.vandenplas
Ik think the only option is to create a dimenstion style with that option off, and use that style to add a threadnote
If you think this answer fullfilled your needs, improved your knowledge or leads to a solution,
please feel free to "kudos"
pveng
Thank you for your suggestion, but the macro will be used by some designing engineers and therefore I want to be independent of single user styles. It should work with different settings.
maxim.teleguz
I have same issue
